Question about Quasar Televison & Video
I have a Quasar VCR model VH200. Cant set year 10
I have a Quasar VCR model VH200. I recently tried to tape a show and when setting the date, it would not take 10 for the year. Is is just too old and I'm out of luck?
  • 3 Answers
Set it for the year 1999.Its the same calender as 2010. For 2011 set it for 1994.
Posted on Feb 25, 2010
I have a Quasar VH6200 VCR. Can it be connected to a new TV and be able to record TV programs. I have connected it but it won't record. What can I do?
I have the same machine and the same problem as you do. Apparently, because this model has a hardwired, built in calendar, it experiences a "Y2K"-like problem and will not record (even manually!) when you either try to program a date that is more recent than 2008, or the machine's present date "hits the wall." The solution is to program a year that is identical to the current year. Example: day and date-wise, 2014 is identical to 1997. So entering the correct month and day, but using 1997 for the year entry will allow normal operation with correct day/date timer operation and the stupid CPU will be none the wiser. As for using this machine with modern HDTVs, there should be no problem as long as the TV has standard analog A/V jacks. For recording the machine would need a source of standard-def video, either basic cable TV or a digital converter box if using over the air signals. BTW, 1998 is a match for 2015, so the above solution will be good for two years. After that, just look up a leap within 1990 to 2008 year that matches 2016.
Feb 05, 2013 | Quasar Televison & Video
I need a manual for a Quasar VV-1305 TV. I
I have a quasar model vv1305 t v -vcr combo. the vcr loads and ejects the tape, but when you try to play or rewind it prints on the screen vcr lock activated . need help
Apr 11, 2010 | Televison & Video
VCR Calendar Out of Date
Program the VCR as if it were 1998. The day date sequence is the same as 2009 (and not a leap year).
This should solve the problem
Jan 23, 2009 | Quasar Televison & Video
Sony VCR date only goes up 2006
Goggle year with same dates as the year you want. It'll show up.
For example if you can't get 2009, then you can set it to 1998. Same starting day, and all other dates will be identical.
Nov 12, 2008 | Televison & Video
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
HOW TO RECORD CONTIUOUSLY
what do you mean? you can set it to record mon-fri or
weekly. you do that on the timer. if you want to record the whole 6 or 8 hour tape
just press record the tape will go off itself at end of tape some vcrs you can set manual timers by pressing record button
more than once and can set to record up to 6 or 8 hours .
if it don't do that just leave it on record it will fill up tape until end
but will stay on same channel.
timers are unreliable if u make just one mistake it might miss
the show.
Nov 11, 2007 | Quasar VHQ940 VHS VCR
Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
Televison & Video Logo
245 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
