Question about Garmin GPSMAP 76CSx Handheld GPS GPS Receiver
Altimeter Hi, I want to calibrate the altimeter of my GPS, and I can't use decimal places. How should I insert a height of 9.45 m? Thanks a lot Paula
Common! It'll never be that accurate!!!
Posted on Feb 21, 2008
What is the need of an altimeter in hiking and climbing?
A barometric altimeter can be used with a topographic map to verify one's location and it is often more reliable than a GPS.
However, barometric pressure changes with weather, therefore hikers must recalibrate their altimeters every once in a while, when they reach a known altitude like a trail junction or a peak that is marked on the topographical map.
Sep 09, 2013 | Measuring Tools & Sensors
What does the Altimeter measures?
The Altimeter measures elevation of your ride. It is useful if you are training for a race and you would like to keep record of your highs and lows.
Jan 14, 2013 | Cycling
GPS elavation
The altimeter requires calibration on the Edge 800.
To calibrate the altimeter:
1. Select MENU > > System > GPS > Set Elevation.
2. Enter the elevation, and select the check box.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 13, 2011 | Garmin Edge 800 GPS-Enabled Cycling...
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
Hello, I don't understand how to calibrate the altimeter
May I get the make and model # of the watch to help you more
Jan 22, 2010 | Timex Adventure Tech Altimeter Barometer...
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Sep 03, 2008 | La Crosse XG-55 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
1. Activate Crystal
2. Press Altimeter
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Elevation Problem
Some models have the Barometric Altimeter which needs to be calibrated, and some units do not.
Vertical Accuracy of a properly calibrated Barometric Altimeter is +/- 10'. If you have a unit that uses provides a GPS Elevation only, a +/- 50' vertical solution is pretty standard.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Garmin GPSMAP 76CSx Handheld GPS GPS Receiver Logo
107 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
