My wireless stop working cable works it was saying turn on a switch but it doesn't have one mx8711 laptop vista try drivers from gateway
    Novelist:
  • 157 Answers
Here is a link to the gateway documentation. There is a notebook reference guide explaining the operation of the computer. One section talks about the network radio and how to turn it on and off by using the Fn and F2 keys. You should see a light go on and off as you repeatedly press those two keys (hold fn down and then press F2). That may solve your problem. If not there are several manuals on that page which should help you out.
Posted on Feb 02, 2010
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
How do I enable the wireless switch on a Gateway mx8711
HI there,
Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide.
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page. Another source of reference for networking your computer is the Gateway Notebook Networking Guide. Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Hope this helps you out.
TheSelkie
Jul 21, 2010 | Gateway MX8711 Notebook
Gateway MX8711 ran hot. Now will not power up
It sounds like the laptop has had some sort of thermal problem. Do you use it in a dusty/dirty environment? Did the laptop blower fan seem louder than it normaly was in the past? Any number of things (including age) could cause a laptop's fan to stop/work ineffectually and cause it to overheat.
Feb 10, 2010 | Gateway MX8711 Notebook
I have been trying to reinstall vista on my mx8711 but before install completes the screen blocks up and freezes and will not finalize installation,try to run fix says bad drivers how do i procede
you may need to re-format hard disk before installing the software as windows will try re-using the existing installation instead of re-placing it. start from the windows cd, then select to go to dos prompt.
type
format c:
then hit enter. this should erase existing data then procede with the normal instalation process
Dec 21, 2009 | Gateway MX8711 Notebook
Gateway laptop wireless driver
send request to need_software@ymail.com
for your driver need
Aug 25, 2009 | Computers & Internet
MX8711 notebook, no sound
Although gateway doesn't provide free phone support for Refurbished models all of the original software can be restored individually from the restore set(assuming you made it) or downloaded for free from gateways website.
If it's simply an issue with the update causing a problem, try re-installing the sigmatel audio driver from the driver and applications DVD you made, or if you didn't make one click the link below and scroll down to the sound section. You can download a fresh copy from there.
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014139R
Hope this helps FixYa,
Chris
May 14, 2009 | Gateway MX8711 Notebook
Screen looses display once logged on but works fine in safe mode
try starting into safe mode and set the display driver to a different resolution that you are sure your computer will display. it may also be an issue with the display adaptor when it switches to a specific resolution setting. windows loads your graphics settings at the time of log on.
Apr 18, 2009 | Gateway MX8711 Notebook
No sound driver working on my gateway notebook pc
Did you check the Device Manager, the audio driver, has it a yellow ? against it or is it OK and enabled? If it is has the MUTE button been ticked?
If it has a yellow ? against the audio driver then the correct audio driver was not installed. Go to the Gateway Support/download page to download the correct XP driver for your model laptop's audio device and install it.
If the sound still doesn't work check Device Manager to see if the driver was installed and working.
Apr 08, 2009 | Gateway MX8711 Notebook
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Jan 12, 2009 | Gateway MX8711 Notebook
Computers & Internet Logo
David Payne
David Payne
