Question about JVC Car Audio & Video
We installed a jvc kd-s26 into my 2002 trailblazer, I believe correctly but the radio will only turn on for about 15 seconds and then powers off.... I do not understand
There are two power wires for the receiver. One will light the clock and eject the CD when the eject button is pressed, but will only stay on a few seconds and this is connected to a battery source. The other power wire actually turns on the radio and is connected to a source controlled by the igition switch Check the wiring diagram to see if you have both wires connected correctly.
Posted on Mar 21, 2011
Did you ever find a solution to this problem. We are having the same issue.
Posted on May 31, 2010
  • caps_pop Aug 24, 2010
    The remote wire might not have enough power. i know this can happen with amps so check it out
Why my am on jvc kd-r600 cuts out?
Am you talking about radio stations or did you mean amp either way check the wiring and if its the amp if could be getting hot try relocating it to a cooler place. let me know
Aug 25, 2014 | JVC KD-R600 Car CD/ MP3 Player
JVC kd-r210 flashes and won't power up?
Sub
You need to look through the JVC KD-R210 manual.
A JVC Dealer / Installer may have seen a similar problem & suggest remedy.
Jul 14, 2014 | JVC Kd-r210 Car CD/ MP3 Player
How to change time on car radio jvc kd-ar260
Hi.
Press and hold Sel button for over two seconds, then select clock to set time.
Please follow instructions at page 9 in manual below:
Instruction Manual - INSTRUCTIONS
Here also installation manual:
KD-AR260/KD-G210 - JVC USA
Aug 13, 2010 | JVC Arsenal KD-AR260
My radio will not work
for turn off this radio press power botton for 3 second. if you press only with one touch is for mute. turn on press one secon---turn off press 3 second---1 touch is mute.
Sep 09, 2009 | JVC KD-G140 Car CD Player
JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Jun 10, 2009 | JVC KD-G200 CD Player
JVC KD-G245 - powers up, then turns itself off after 3 seconds
Try connecting battery and accessory wires as one instead of two seperate wires (yellow and red) had same problem and worked for me(it will not be neccesary to turn the key for the radio to work once this is done)
Mar 05, 2009 | JVC KD-S580 CD Player
Car radio - setting the clock
1. click on S (select) and choose clock and hold it (?) 2. click on bar v|<< >>|> to select H or M or Seconds 3. adjust it turning the volume button 4. repeat steps 2 and 3 for minutes 5. repeat steps 2 and 3 for seconds
Dec 12, 2008 | JVC KD-G510 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
706 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
