Question about Intel Motherboard
Safety of mother board and processor
What is the maximum allowable voltage between neutral and earth to avoid burning or failure of product
  • 4 Answers
Connect any good cabinet which involves a good power supply comprising of smps (Switching Mode Power Supply) again it also consists of four cables yellow (12v), Red cable (5v) and other two black wires of ground check the voltages with a voltmeter then you can avoid burning or failure of product .
Note : Ask your electrician to provide better earthing to your computer
Posted on Feb 19, 2008
What is the current draw on an omega Europa 40-1 elec oven please
7
ELECTRICAL INSTALLATION
WARNING
This apparatus must be earthed.
The oven is only for domestic use.
The feed voltage and the absorbed power are as indicated on the data plate attached to the left-hand side
upright, which can be seen when the oven door is open.
Connecting must be carried out by qualified personnel and in accordance with the regulations currently in force.
The manufacturer cannot be held responsible for any
damages to persons or objects caused by failure to
observe these instructions.
If the supply cord is damaged, it must be replaced
by the manufacturer, its service agent or similarly
qualified persons in order to avoid a hazard.
The oven must be connected to the mains through a multipole circuit breaker with a contact-to-contact
gap of at least 3 mm, making sure that the earth wire is not disconnected.
For connecting use a flexible cable of the
H05V2V2-F 3x1,5 mm2
type remembering to make it long enough
to allow the oven to be removed from its housing un
it when maintenance work is required.
To connect the cable to the oven, proceed as follows (see Fig. 2):
- Remove the lid (1) by unfastening the three screws (2).
- Unfasten the two screws (3) for the cable holder
and feed the cable through the opening immediately below
the cover.
- Remove about 12 cm of the outside insulation from
the cable and shorten the two active wires (live and
neutral) to 6 cm, leaving long the one to be connected to the main earth terminal on the terminal box;
remove about 1 cm of the main insulation from the three wires and connect them correctly to the terminal box,
Remembering to respect the polarities.
- Tighten the two screws (3) of the cable holder and put the lid (1) back on with the three screws (2)
Electricals Specification
Absorbed power:
Oven top element:
2000+1000 W
Oven bottom element: 1200+400 W
Lamp:
25 W
Hot air fan motor:
25 W
Cooling fan motor:
25 W
Maximum absorbed power:
(see data plate).
Supply voltage:
(see data plate).
Aug 22, 2017 | Ovens
Bike is 2003 ultra only23000mi. ecm burned out replaced it and now after about 100mi burned it out again and TSSM . when this happens headlight running lights and signal blow but now fuses
have the voltage regulator tested or replaced
bulbs blowing are an indication of over voltage and the ECM failure is also over voltage
maximum voltage allowed is 14.8 volts dc and any thing over that is deadly to 12 volt equipment
take it to an accredited motor bike electrician and have the system checked
Nov 27, 2016 | Ultra Motorcycles
Am/fm tuner no power
Try changing the cable/transformer for a new one. you should be able to find a new cable online easily enough, or maybe a friend has one you could borrow.
Try a different power outlet.
Make sure your multi-plug (if you're using one) is functional.
Try plunging something that you know works, in the outlet, to see if you have power at that plug.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
It could be a fuse in the Tuner, replace the fuse for a new one.
Get your Multi-meter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Sony Audio Players & Recorders
Motor will not start
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
Inspiron 620 desktop will not power on. Change out of power cord was done whilst under warranty (7/12-7/13). Purchased 7/13. Warranty is up. Have not tried to power on since August--it powered up then....
A computer will not power on in certain conditions follows
  • RAM Failure. i.e, RAM is not properly inserted into the port, or any dust particle presence in its port, I am sorry to say The RAM is in DEAD condition
  • Mother Board Failure. Any overflow of power enters into the motherboard. motherboard will burnout (due to lightning, Voltage level increasing etc)
  • Power Failure
  1. When the power cord is properly functioned or loose connection
  2. SMPS is under malfunctioning (SMPS Burn out)
  3. Power cords from smps to mother board,HDD,CD drive fail
  4. Short circuits etc
Check it out...
Jan 22, 2014 | Dell Inspiron 620 ST Desktop Computer...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
IDE HARD DISK
Normally 137gb but updating the bios will allow a larger size to be recognised.
Oct 05, 2007 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
