Question about GPS
I Wish to the wiring on a JFV-130HP from 50khz to 75 khz
  • sl_horton Feb 03, 2010
    Dear Javaman Thanks for your imput but the imfo you sent me is the factory settings,with the help of an eastern states technician today we have reconfigured the echosounder to use the different transducer frequencies,all the sounders are built the same and there are bridges on the main board to set the operating frequences these are the ones i needed to change ,all is well now Regards Scott
    President:
  • 547 Answers
There should be a full model number after the 130HP, for example:
130HP E LM B
The first letter will be E for English display, J for Japanese display.
The second two letters define the frequency or frequencies for the transducer:
K = 200KHz
L = 70KHz
M = 50KHz
N = 28KHz
W = other
So, if your model number has LM in that part, then you have a 50/75 dual frequency model, and you can select one or the other frequency in the on-screen setup.
If you DON'T have LM in that part of the model number, then your model isn't built to support those frequencies, and it's more than a simple rewiring to change it.
Posted on Feb 02, 2010
  • Rob C Feb 03, 2010
    Great! I'm glad you're all set now.
How do i reset a sony STR-K740P receiver??? - Sony Str-k740p Radio Receiver
Tuner reset
You can change the AM tuning scale to 9 KHz or 10 KHz. After tuning in any AM station turn off the receiver. Hold down the Preset tuning + and - ve together.
All preset stations will be erased when you change the tuning scale. To reset the scale to 10 kHz (or 9 kHz), repeat the procedure. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 12, 2016 | Sony Audio Players & Recorders
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
    170
  • Vertical Viewing Angle
    160
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
Have a Toshiba 500GB external hard drive, model: HDDR500E03X and I've been using it for some time on a few of my computers, but lately it hasnt been displaying. I dont know much about Ubuntu to begin...
Sounds like some kind of bad wire, you hope. It could be a power issue as you have stated, I would try it out on several diffrent computers, and you were not wrong in trying the y cable. But if that still doesnt work then not all is lost. I would recomend opening up the caseing and removing the hard drive. Even external drives simply use standard laptop SATA drives. If you have a desktop you can simply plug in the drive while your computer is off, if you do not have xtra spots to plug it up you could temp unpulg your dvd drive to test it. If you have a laptop than you can buy several devices to use a sata drive though usb. http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071&cm_re=usb_sata_docking_station-_-17-153-071-_-Product
This is the one I use the most.
Good luck , if you have any questions let me know
Prodigz2
Mar 12, 2011 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
My yamaha 130hp outboard starts and runs good but
The carbs need to be cleaned.There is a high speed jet in the carb that is more than likely stopped up. Jim OMC retired mech.
Jul 07, 2009 | Boating
Frequency increases/decreases in steps of 0.2 kHz
Hi again, Seems you posted twice. A copy of my reply to your other post.... Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
