The washing machine displayed E91 on the display and has powered down. This has happened once before and the unit after not being used for a couple of days started to work again.
-   We have the same problem, i.e. the washer comes up with E91 error code and stops. We have had the controller board replaced once and it now has the same problem again. Electrolux does not seem to have a fix for it. They just want to replace the controller board with another faulty one. We are fed-up with Electrolux and about to return the units to the store and get a different brand !
-   Guest
Jun 06, 2008
-   ho una Lavamat AeG che fino a ieri è andata perfettamente, oggi, l'ho caricata e una volta impostato il programma, sul display è apparso E91, lampeggia suona e non funziona più. ho spento e riacceso. staccata la spina e riinserita. non funziona
-   Guest
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer. No power Check the flex, plug wiring, fuse and mains supply for faults. Faulty on/off switch Check the power light if fitted. Replace your on/off switch. Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Was this helpful?
Yes
No
Popular Solutions for AEG Lavamat 72640 Front Load
my aeg lavamat 72630 is coming up with e20 and wont finish a load i dont think its pumping out water...
(More)
my aeg lavamat 72630 is coming up with e20 and wont finish a load i dont think its pumping out water but it is taking it how do i fix it/what should i do?
my aeg oko lavamat 72640 update keeps stopping in the middle of programmes. Sometimes the stop/pause...
(More)
my aeg oko lavamat 72640 update keeps stopping in the middle of programmes. Sometimes the stop/pause button flashes but pressing it doesn't restart the programme. At other times the indicator shows a large amount of time to go but the programme can't be restarted. It all started when I tried to do a 60 degree cotton wash. I am forced to run the "drain" programme then the "rinse" and try again with different programmes. Intermittently, I am managing to do a 40 degree easycare wash but not every time. Help!
during washing some water drain under the washing machine please , and this water become electrical...
(More)
DURING WASHING SOME WATER DRAIN UNDER THE WASHING MACHINE PLEASE , AND THIS WATER BECOME ELECTRICAL SO ITS DANGER FOR USER , PLEASE SEND THE BEST SOLUTION
