Ricoh Aficio 1032 Network printer problem
Hello, i have a Ricoh AF1032 copier, i have installed a network module for printing, and memory.
I can see the status of the copier via TCP/IP, i can ping the copier, but i can't print.
i have tried 5 or 6 drivers and still doesen't print.
In service mode if i select Scanner free run , it runs the scanner
if i select printer free run, nothing is happening.
The copier works great as a copier.
Thanks.
  • Botez Adrian Feb 05, 2010
    Ok, i have foud the problem, i installed a PostScript3 module not a PCL module, and the drivers are for PCL.
  • 155 Answers
See if it is your default printer.
Posted on Feb 04, 2010
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Hello I'm in Brazil can not resolve error in my SC990 Ricoh Aficio 2045eSP. This error pops up after 10 copies or printing. Already exchanged cylinder, blade, developer and toner new. Please help me.
Why change the drum, blade, developer ????? You had problems with print quality?? I think it was just spending money ....
You have a network problem or machine firmware. To remove the doubts plug a laptop directly to the machine with a cable (Not necessary a croos cable). This may be a virus network or a broken swith.
Good luck
Feb 11, 2011 | Ricoh Aficio 450 Copier
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
May 29, 2010 | Ricoh Aficio 2015 Copier
Use ricoh aficio 220 as network printer
If you have the print/scan option installed on the copier, just to go the Ricoh website and download the print driver, and you can use it as a network printer.
Feb 23, 2010 | Ricoh Aficio 220 Laser Printer
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
I'm trying to print on a Ricoh 1035 from a Mac. Is this possible if it's on a network?
Its possable to print to a networked ricoh 1035 from a Mac... You need the Postscript option...
Jul 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ip adress set up
try factory restore settings
Apr 19, 2009 | Office Equipment & Supplies
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
288 people viewed this question
jasbo
jasbo
