Question about Dryers
Replacing on off switch? dryer will not turn on when you hit switch,timer works
  • 767 Answers
I would check the door switch too. This could be kepping the machine from coming on because it thinks the dryer door is open.
Posted on Feb 02, 2010
When the timer on an electric dryer fails to start the dryer. Should you still be able to hear it ticking, when the timer is turned on?
Of course. Correct diagnosis is the key to such things. All the items you swapped out were fine. There are checks you can make with all those components. The rotary type timer is just a clock timer like a wind-up alarm clock. When you turn them on, they tick. In normal circumstances, turning it on will start the machine, and not count down. You need to remove it and make sure you have continuity and also power to the timer. There is more to this than meets the eye. The other item that it may be, is the motor itself.
Nov 25, 2017 | Dryers
The dryer won't start. the timer is ticking, but ...
check the door swich see if it is catching,,,,the switch is on the inner part of the door frame,,,,if that dose not work look into the thermofuse ....if dryer making a nose atattempted start up you may need a motor,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
The dryer will not run its cycle, the drum does not turn nor does the fan run. However, the timer counts down as though it is running a load. Door is tightly closed and temperature in room is not below 32...
I have a g e dryer modle # dblr333eeocc when i hit the start botton the dryer just hums. If i spin the drum by hand and then hit the door switch the dryer will work untill you open the door
Feb 17, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
