Question about HP Officejet 4355 All-In-One InkJet Printer
I lost my c.d..i want to scan letter ,how can i.. ?
    Novelist:
  • 157 Answers
Since you did not provide the operating system, here is a link starting at the operating system which will allow you to download what you need including documentation.
The link is:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1138373&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Good Luck - Leave review info
Posted on Feb 02, 2010
  • 109 Answers
HP Photosmart C309a default scanner paper size
Hi Norman,
Are you trying to scan from Printer to PC or Activating SCan option from PC ?
On your PC, Open Solution Center
Click on Settings option below
You will find Scan document options - select it
you will find the Size of paper set, Change it to Letter
Regards,
Sean
Jan 31, 2013 | HP Photosmart Premium C309A All-In-One...
My Beyond Micr 250GB external HHD is not showing up on my PC running windows 7 and I have 2-1TB SATA HHD installed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover lost files.
http://www.asoftech.com/articles/External-Drive-Data-Recovery.html
Aug 28, 2011 | Beyond Micro 250 GB USB 20 Hard Drive
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
The Maxtor harddrive was moved and the plug got jiggled so it wasn't showing on my pc...I fixed the issue, then kept getting an error message "checking dish one touch" with 2...
Open My Computer
Note the drive-letter assigned to the Maxtor
Close My Computer
Click Start
Click Run
Type CMD
Press Enter
If the drive-letter was 'E:', type 'E:'
Press Enter
Type ATTRIB -H -R -S *
Press Enter
Open My Computer
Double-click the icon for the Maxtor
Does it still show "zero" files/folders?
Does it show a 'FOUND' folder?
What file(s) are in that folder?
Nov 02, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Scan letter
Most scanners in my experience do not scan to "precisely" 8 1/2 X 11 inch letter size (assuming that was the original paper size).
A workaround is possible with some graphic programs. After importing the original incorrect scan of the document into the software a combination of resizing and/or cropping (depending on how your program works) will allow getting the exact dimensions. Then save as a new image document. Make sure to adjust for sufficient resolution (a larger document) if you plan to reprint.
Jul 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not scan legal documents
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-4
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
I have lost my tv remote for my syphonic tv
One website gives instructions on how to use the AUTO CODE SCAN feature of your remote, even if you don't have the code numbers. Take the following steps to access this info.
Step 1) Type REMOTECODELIST.COM into the Google searchbox, and click on GO or SEARCH.
Step 2) Once you are on the website, scroll down the page until you see JENSEN in big red letters, on the left hand side.
Step 3) Look under JENSEN for SC-540 ( in purple letters), and click on SC-540.
Step 4) Look on the right side of the page for instructions on how to do an AUTO CODE SCAN.
Hope this helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 15, 2008 | Symphonic ST420FF 20" TV
HP Officejet 4355 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
