Question about Microsoft Windows Vista Ultimate Edition
Program which has lost its path.
Firstly, I have 4 programs named: Rundll which have lost their path. I believe these are from a Jagex program as my son once upon a time constantly played on Runescape – an interactive game.When I purchased the computer it came with no discs and I did not know at the time I should have made some back up discs.I believe my options are:
  1. Unistall all the programs that I believe we have loaded – but I’m not sure which these are ?)
  2. Run a systems restore from the beginning and then reload word etc, then run a disc frag (clean up) and then create a back up disc – but I don’t know how to do all this ?
  3. Load my copy of Windows XP and then word etc as I have the discs for this for my other computer and then remove Windows Vista.
Please can you advise which method I should use.
    Novelist:
  • 188 Answers
Hai,
It sounds like you are very much familier with computer and you do not what exactly needs to be done, no problem we are here to help you.
If the problem is not more than 14 days then, I suggest you restore the computer else.
Please uninstall the game or application that you are facing the problem with, if this could not fix the issue then I suggest you format the computer and reinstall the operating system, to reinstall the operating system I will provide you a weblink which has detailed information on installation of XP.
http://www.petri.co.il/install_windows_xp_pro.htm
similarly you can find vista and windows 7 installation guides, please make a note of the steps and perform the installation.
This should fix the issue.
Bye, take care
Posted on Feb 03, 2010
Is the module RunDLL very useful?
It is essential to run many windows programs.
More info required to give an answer
Jul 09, 2014 | Acer Aspire Computers & Internet
Tip
HOW TO START PROGRAMS IN WINDOWS STARTUP (XP)
Step 1 : Start --> Run --> type regedit and enter.
Step 2 : inside regedit go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Step 3 : On the right side window, right click and select NEW --> String value.
Step 4 : Now you can see a new file, Give appropriate name Here I'm using Internet Explorer.
Step 5 : Double click the created file and enter the path of the Program you wish to startup. Here i'm using internetexplorer path.
Step 6 : Close the registry editor and restart the machine.
Now you can see the Program was running after login.
Thanks
Current_Support
on Feb 18, 2010 | Computers & Internet
How do i remove run.dll2 from my computer?
Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
  1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
  2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
  3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
  4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
  5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
  6. Restart your computer and the Rundll error will be corrected.
Save a tree.
Apr 28, 2010 | HP W19b LCD Monitor
I keep getting a rundll error i am unable to run internet expoler
This problem could have happened due to an incorrect program removal procedure. You can hence try to fix it by installing the program that has been removed and to correctly uninstall it either with the Uninstall option proposed by the program itself or through the Add/Remove feature found in the Control Panel menu.
  • 1. Go to the Start menu and open Control Panel
  • 2. Select Add/ Remove program option and locate for the program that you want to remove and click Remove.
  • 3. When the procedure is over, delete any shortcuts that could have stayed and empty the Recycle Bin.
  • 4. Reboot your system
Jan 31, 2010 | Microsoft Windows Vista Home Basic Edition...
Sir, System when start the RUNDLL error notice shown. The errorloading path is ; c:Program FilesMywebsearchar.binM3plugin.dll Pl.solve Ok.
Ok, first it seems that you uninstall manually the MyWebsearch application. You can try running System Restore, which it may help. Otherwise you need to clean the registry to get rid of the unused registry key that your Operative System is looking for. There's a free software called Advanced System Care Free which is very handy and user friendly. Install it, run it and it should fix the problem. Good luck
Jan 03, 2010 | Computers & Internet
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL
It appears that a program has been removed (not uninstalled) from the computer and XP can no longer locate the removed files while references to the files still exist. So, we need to find what is referring to this file. The easiest way would be to download, install and run a registry cleaner such as CCleaner (from www.download.com), but this can also cause more problems than it solves. The other way is to use the msconfig utility to disable all of the extras that are loading and then enable them one by one and rebooting each time until the problem appears again. Then just disable the last one enabled (that caused the problem to reappear), and continue on until all other programs and processes have been reenabled.
Apr 07, 2009 | Microsoft Windows XP Professional With...
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
Microsoft Windows Vista Ultimate Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
