Question about Dewalt Saws
De Walt Power Shop DW125. Cutting problem.
Circular blade is snatching wood away from operator's control during use.
  • 122 Answers
Sounds like a dull blade or not enough teeth on the blade. Go with atleast 40 tooth.
Posted on Feb 02, 2010
Can I use my metal chop saw to cut wood if I replace the blade with a wood saw blade?
Its conversely sometimes possible if you was asking about a wood saw with a steel saw blade but i cannot advice that in both application its not safe because not only of the difference of power but most it is the much higher RPM by diameter, just beware always on the max rpm you can read on your saw blades!!, it can give strange accidents with objects it can grab and swinging outbroken parts away.
Sep 28, 2016 | Makita "2414NB 14"" Chop Saw"
Why does my wood that I'm cutting constantly jumping?
Hi, it may be that your circular blade needs sharpening or a new blade.
Feb 24, 2016 | Saws
When cutting 7.5" laminate wood floor with 12" miter saw. When we cut, the very end of wood(1.25"at the same place on every piece). Does this mean blade is dull?
Hi Shaun:
Just a couple of things to try:
- Make sure the laminate is supported at both sides when cutting.
- Make sure the laminate is held firmly against the fence and deck when cutting.
- Do not "rush" the cut. Laminate is very hard and does not like to be hurried.
- Make sure that the correct blade (teeth) is being used.
- And yes, the blade has to be SHARP
Jul 25, 2015 | Saws
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
When using saw the blade comes to a stop on its own thro wood
Does the motor continue to run? If so, the blade retaining bolt may not be tight enough. Most saws have a 'stop' pin which locks the drive during the blade tightening procedure. Make sure the blade is very sharp to reduce cutting effort. Hope this helps!
Feb 07, 2010 | Saws
Operating manual
Hi hope this helps you!!
The link bellow will take you to de walt sight on there you will see your saw, on the right of the screen you will see "documents" There you can click on what you are looking for its a good sight for the future so save it!!
Hope that helps. Sean.
https://service.toolcommerce.com/Products/ProductDetail.aspx?ProductID=2906
Nov 09, 2007 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
640 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
