Question about Acer Aspire 5735-6694 Notebook
Acer aspire 4730z notebook usb ports not working
I had tried with BIOS setup, opened the motherboard of the laptop & cleaned it with industrial pcb & components cleaner liquid, no any damage found, checked the usb controllers driver they r up to date & dont have any conflicts, but whenever i will plug in the usb pendrive or card reader tht will not work even no any power supply shows on the usb stick???????
kindly tell me at which point i have to do the trouble shooting?
sandrew
  • 2961 Answers
SOURCE: USB ports not working Acer Aspire laptop
Two solutions would be to either restore your pc to before the problem started,using system restore on accesories menu, or use the recovery cd or the recovery folder Acer laptops usually have on the 'D' drive and re-install usb controllers and drivers.
Posted on Nov 24, 2006
  • 121 Answers
SOURCE: Acer aspire 5610z card reader
goto to start menu
click on my computer--this will show all drives and devices
find your media reader drive
right click on that--goto properties
click and you'll see different tabs, so go thru each of them
and try to restore all defaults--
not sure what os you are running on so let me know if i was of any help to you.. thanks, d
Posted on Feb 27, 2008
TampaNative
  • 778 Answers
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
Please try another SD card as to eliminate the card as the source of the problem. As you mentioned uninstalling and reinstalling the driver in Device Manager you may want to "Roll Back Driver" there as an update could have caused this problem initially and reinstalling the updated driver wouldn't solve it.
Post back your results so that we may continue to help you troubleshoot this issue?
Thanks and good luck.
Posted on Jul 15, 2008
i changed my hard drive .. and my computer has an SD slot .. but it wont read my card when i insert it .. odes it have to do with the new hard drive .. what can i do ..
Posted on Sep 10, 2008
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
Flash bios on acer aspire one aod250
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Jul 24, 2013 | Acer Aspire One PC Notebook
Bipra harddrive not reading on pc
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM There is a connection problem such as a bad cable for internal hard drives
Apr 03, 2013 | Computers & Internet
Problem with my HP Mini 110 PC Notebook
Your best bet is to just take it back to the store and get a new laptop
Dec 08, 2012 | HP Mini 1000 Netbook
Spilled coffie on toshiba satellite l505-es5018 powered it off let dry opened it to look at damage not much on the mainboard but it wont power on when you plug it in to ac the fan runs as soon as u plug...
Anytime where liquid is introduced to a keyboard, witch is a direct input to the main board its without question that the main board would be effected. A main board has a BIOS Basic input and output system. When a motherboard shows sign of life with errors you would here some beeping. Whilst you hear nothing but fans so yes I would put my opinion on the main board.
Coffee most likely with sugar and cream, not all like it black. If this is the case or not the case its still liquid and a laptop is powered by a battery turned on or not. Anytime liquid touches a PCB board in layman's terms Motherboard your going to have damage.
Repair would be costly as you would need a new main board,keyboard shoot you might just want to purchase a new laptop at this point given there dirty cheap now days.
Thanks for the question, I hope my answer was Helpful, please do not forget to rate and leave feedback!
Thanks and best regards,
Rulds2008
Jul 27, 2011 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
I have spilled just a spoon of water on my laptop, after it the keyboard is not working a t all, i cant even log into bios. i have sony vaio vgn z series laptop, i tried to delete the driver, and when...
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Jan 16, 2011 | Computers & Internet
A glass of wine was spilled on my laptop. It would still power up but the screen was black. Now it won't even power up. Is it worth getting repaired, or should I get a new one?
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
If it still does not work, the motherboard might be damaged & needs to be replaced.
Oct 21, 2010 | HP G60-235DX Notebook
I have a Lenovo ThinkPad t410s. Wine as accidentally spilled over the keyboard, and now the laptop will not turn on. How can i fix this computer? Is this something I will be able to do on my own? Thanks.
Oct 18, 2010 | Lenovo ThinkPad T410s Laptop Computer...
I spilt a little water on it yesterday! It continued to work fine. But now today, the battery light is off and on flashing even though I have it plugged in and it will not turn on.
1. Unplug the AC adapter.
2. Remove the battery.
3. Disassemble the laptop & clean all internal components.
4. Assemble it back & test it.
When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Oct 06, 2010 | Dell Latitude E5500 Laptop
I have a friends laptop, which he spilt a cup of tea over, he wants it repaired, when i got it it would not come on at all, but after a few hours of playing about with it, i got it to boot up into...
First thing is to not try powering the laptop on after the liquid fell on it. Next, you should remove the battery off the laptop immediately. When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check the hard drive's connector to the motherboard for any liquid damage & clean it.
Aug 26, 2010 | HP Pavilion dv9000z Notebook
I broke my USB port on my Acer Aspire 4730Z. How
open the laptop, desktop pc, and remove carefully the internal usb connector, that goes to the motherboard, BEFORE ANYTHING DISCONNECT THE POWER CABLE, AND EVERY SINGLE CABLE ITS CONNECTED TO, MOUSE, KEYBOARD...ETC. then see which kind it is, and go to your local hardware store, Best Buy, Fry's, or order it online.
Reply: team.akwrite@gmail.com Irving
Mar 16, 2010 | Computers & Internet
Acer Aspire 5735-6694 Notebook Logo
572 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
