Question about Dryers
No heat Whirlpool dryer LGR5620KQi does not dry clothes. I checked through the "peephole" in the front and didnt see the gas fire up. No clicking noise, coul dthis be an issue with the ignitor? How do I open up the fron t of the washing machine?
  • raghukrish Feb 06, 2010
    Yup..you were right the issue was the thermal fuse. I got a new one from Sears for 15$. Works great now.
    Thanks for your help and saving me the time and money to repair this.
    President:
  • 1,218 Answers
Good day,
You will need an ohm meter to test components.
The first step, is to remove the back cover, and look at the center near the bottom for a skinny white Bakelite device held in with one screw. Remove one wire, and test for continuity. It should show zero ohms. If not, replace, It is the most common cause for no heat.
As well, if it checks O.K. then look around the area your in. There are about 4 to 5 thermostats (round or rectangular) that have to be tested in the same manner. Any one of them could cause no heat.
You are correct, in that it may be the igniter. You have to remove the front cover panel, and unplug the igniter from the gas valve assembly. It should check below 30 ohms. If it reads infinity (no continuity, then replace.
I've included a tutorial. It doesn't apply to your issue, but does show you how to access the gas valve area.
http://www.applianceaid.com/wp_element.html
Posted on Feb 02, 2010
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
My whirlpool dryer LEC7858AN2 is not heating when drying clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][\
Apr 13, 2011 | Whirlpool LER4634J Electric Dryer
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is not getting hot, not drying clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 07, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
