Question about Electronics - Others
I have bought HP 8 GB Pendrive from Ebay.in before 8 days But it is not working Now It shows error that pendrive is Read only What is the solution?
  • 813 Answers
What is the model of your HP Pen Drive?
Is there any small slider switch on the pen drive? usually there is one on the SD memory cards to lock and unlock it. If the switch is in locked position then the memory card/pen drive will be read only and if it is in unlocked mode then you can write to it.
In case there is no switch on the pen drive, then try formatting it and check if you can format this drive or not? You may also try accessing/formatting the drive from some other computer.
Posted on Feb 02, 2010
  • Dixit Sardana
    Dixit Sardana Feb 02, 2010
    Did you check for the switch or just rated the solution?
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
My 8 gb toshiba pendrive is not detected by the computer.. what shud i do? my pendrive model is FC n723 d32210....
My 8 gb toshiba pendrive is not detected by the computer.. what shud i do? my pendrive model is n723 d32210....
Sep 17, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I have a kingston 8gb pendrive i had tried to make a bootable pendrive by using command prompt and i failed. I also made my pendrive partition so capacity of my pendrive falled from from 8 gb to 3.44 gb. I...
Most of the time running a disk check first will fix your problem.
Right click on your drive's icon in "My computer"
Select properties. Go to the "tools" tab, select "check for errors".
Depending on the operating system you use, this could also be called "run scan disk", "run disk check" or "check for errors".
Jan 25, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Pqi 8gb pendrive showing the error 0x8007045d
It seems that the drive may have corrupt data sectors. Unfortunately this is not generally repairable with flash memory, and you should take the pen drive back and have it replaced under warranty.
Mar 27, 2010 | Electronics - Others
Showing an error ''insert a disk in removable media''
Its happened for my Transcend 4 Gb pendrive. I format dat using ONLINE RECOVERY TOOL from Transcend. Now its workin :-) :-) :-)
Dec 16, 2009 | Electronics - Others
Pendrive not formatted
if u still having the same problem, follow these steps:
1.Insert your pendrive. open mycomputer, note the respective drive showing pendrive.
2. Then go to run and type cmd ( or go to command prompt)
3.It will show like: C:\> or C:\Documents and Settings\UserName>
4.Type the drive name of pendrive as shown in e.g
if drive is h: then type as
c:\>h:
h:\>format h:
it will format and ask for media name, you can give the name of your pendrive.
your pen drive is formatted. Now it will show the free space as 8G.B
Sep 13, 2009 | Transcend (589307) Media
Cannot format my pendrive
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Apr 10, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Imation pendrive not working
sir my pendrive is not working well . it is not working on any computer. sir plz tell me what do i do. it is showing in my computer but not responding.
can u help m,e
sarwar from greater noida
Jul 30, 2008 | Transcend (589307) Media
Electronics - Others Logo
69 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
