Question about Denon DRA-685 Receiver
Dra-685 the protection came on ,i found 2 speaker wires together,fixed that,but still stays on,thanks
    President:
  • 2,992 Answers
You may have a speaker that is damaged and causing the protection to operate. Try unhooking all the speaker wiring from the receiver, turn the volume to minimum, and see if the protection still comes on. If the receiver is okay, you can start checking the speakers and wires to determine which one(s) may be responsible.
If the unit continues to go into protection even with no speakers connected, the trouble is inside the receiver. No protection circuit is absolutely perfect, so it's possible something failed before the circuit kicked in. Without the proper test equipment and service information, you won't be able to try fixing this yourself. Take the unit to a shop for an estimate.
Thanks for using Fixya! Hope your receiver's back in service soon.
Posted on Feb 02, 2010
How to take protect off a denon receaver
Hello. DC Protection is not something you can turn off. It is a protection system engaged by one of the microprocessors (computers) within your receiver. If any of the amplifiers are bad, and producing DC voltage at the output, the micro will immediately turn the unit off, to lesson further damage to the amplifier or speaker system. There can be other causes of why the unit's DC Protection relay is not engaging, but 90% of the issues, are related to amplifier damage.
Dave
Jun 15, 2012 | Denon DRA-685 Receiver
The protection mode want go off from my reciver denon dra 685
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 20, 2011 | Denon DRA-685 Receiver
I push the on button on my DRA-685 and nothing happens .... the standby light is on ..... same thing happened 6 months ago and I took it to a local "fix-it" guy, went to pick it up and he said...
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 10, 2011 | Denon DRA-685 Receiver
What can i do to be able to take my denon dra685 out of protection mode??????
I just recently picked up a Denon DRA-685 receiver that was stuck in protection mode. I found a site online that suggested it was due to two bad resistors on the main circuit board. More specifically resistor R-105 and R-106. They are both 1 ohm x 1 watt resistors. I ordered these from a supplier on Amazon for a few dollars, and just snipped the old resistors off, leaving the soldered leads sticking out. I then thinned the new leads and soldered them to the protruding wires, so I didn't have to remove everything. The unit now works like new. I'm happy I spent the time doing this, and grateful to the tech who discovered the common problem with this unit. Hope this can help somebody else. H
Nov 14, 2010 | Denon DRA-685 Receiver
I cant get any sound to come out of the receiver. I checked that the speaker wires are not touching. if it is in protection mode how do I get that turned off
Good start checking your speaker wires. A better test would be to disconnect them entirely in case there's a short inside the speaker itself. Keep the volume WAY down when you power back up and see if it runs for a while. If it does, then you do have a short somewhere - probably inside speaker. If it trips off, you might want to think in terms of getting the problem fixed rather than defeating the protection circuit.
Nov 11, 2010 | Denon DRA-685 Receiver
Flashes protection
Yes, I agree with the expert, if problem still not solved after removing speaker wires then receiver got problem in amplifier output section and most likely output chips got bad.
Flashing protection is an error sign and unit wont power up to avoid further damage.
Visual check by experienced tech is required to fix the issue. Local repair shop will help you for that.
Jul 27, 2010 | Denon DRA-685 Receiver
THe word Protection is coming across the screen instead of input or other
Dissconnect the speaker wires. If you still get the protect message you have a bad output stage in one of the amp channels. If the message does not appear you have a shorted speaker wire or a bad speaker. If the amp is bad you could still have a bad speaker or shorted wire that could have caused the amp to fail. Resolve this before reconnecting to the repaired amp or failure will reoccure.
Oct 31, 2009 | Denon DRA-685 Receiver
Right channel not working
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
Denon DRA 685
Could it be that the speakers load is too much for the amp to handle? What are the ohm ratings? It should handle a low load but I am just wondering? How effcient are they?
Nov 29, 2007 | Denon DRA-685 Receiver
Protection error
your loudspeakers tweeters have shortcut *try them separetly)
Sep 08, 2007 | Denon DRA-685 Receiver
Denon DRA-685 Receiver Logo
300 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
