Question about Gigabyte GA-8KNXP Motherboard
GA-8KNXP 4 X 1 GB Ram Bios shows 3.500 GB - Gigabyte GA-8KNXP Motherboard
  • 415 Answers
This is because you are running 32 bit system. 32 bit system can only use up to 4GB RAM theoritically but some only 3.5 GB RAM.
Only 64 bit systems can use 4GB RAM and more.
Posted on Feb 02, 2010
Testimonial: "IT was helpfull, because it means that the board is o.k."
  • 115 Answers
This is not a problem, actually sometimes bios shares some amount of memory. So this is not to worry.
Regards
Ashly
Where is the Driver for a SataI HardDisk when installing Windows 7, which is attached to a Gigabyte 8KNXP Motherboard? The Gigabyte 8KNXP Driver Download site has a Driver but it's for Windows XP.
According to Gigabyte, you have a Silicon Image 3112/3152 SATA chip on that motherboard. Below is a link to the Silicon Image support page. Here, under the Product support pulldown you will choose either of the two numbers (3112/3152) and scroll down the list and you will find a driver for Windows 7 for 32 and 64 bit 3x12 chips (where the x is any number). They also say to use the newest BASE BIOS and there are tips to update the chip's BIOS. I've never tried this before, but hope you have good luck!
Support Library
Nov 08, 2015 | Gigabyte Computers & Internet
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Installing 4 SATA hard drives on the GA-8KNXP mobo
check motherboard manual it seems you may have the sata drives plugged into wrong number socket they should have numbers on them sata 1 etc
Jul 28, 2008 | Gigabyte GA-8KNXP Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Cannot load windows
hi cpfish,plz do let me know what kind of error message do you get when you are doing the setup so i can get you the best solution.
raj..
May 12, 2008 | Gigabyte GA-8KNXP Motherboard
Memory DDR
have you checked the memory settings in the bios check the manual how to do this
Feb 20, 2008 | Gigabyte GA-8KNXP Motherboard
GA-8I945P-G 4GB Ram Problem
you maybe have integrated VGA card or Shared memory VGA card that use the memory in your pc .. your best solution is to buy new VGA Card that have dedicated memory
Dec 28, 2007 | Gigabyte GA-8I945P-G Motherboard
Gigabyte GA-8KNXP wont goto POST
The Power Supply dude/dudette, Ive jst gone through the same thing and found Power supply was fried... Got it working fine now... gotta update Bios tho.
Sep 18, 2007 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP Motherboard Logo
187 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
