Question about Canon CLC 1150 Color Copier
Fault Message My printer has got a fault message what am I supposse to be checking or doing wrong???
  • Vika Rarealba
    Vika Rarealba Feb 19, 2008
    Error that's the message could you tell me what I'm doing wrong?
    Sergeant:
    Champion:
  • 310 Answers
What error message is coming
Posted on Feb 19, 2008
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Error message PAPER OUT and PLATEN CAL required Tally 6218. Please help me. Esli mojno po ****** otvet daite. subat@mail.ru
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Oct 11, 2011 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Fault message comes up after the printer is powered on
That is a print head fault. Most likely the print head itself has failed.
Mar 11, 2009 | Xerox Phaser 8550DX Laser Printer
Error and Blinking
i have lost my set up dis for hp 1315.... how do i get free downloader
Mar 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hammer voltage 2
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
Replace the
Controller Board
Jan 08, 2009 | TallyGenicom 6312 Matrix Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Printer Fault
USB port is set wrong on driver...
Unplug usb, delete driver, reinstall driver, plug usb in only when directed by install
Jan 15, 2008 | Brother DCP-7020 All-In-One Laser Printer
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon CLC 1150 Color Copier Logo
27 people viewed this question
old marine
old marine
