Question about Metrologic Instruments Voyager Hand Held Scanner USB POS (mk9540-72a08) Handheld
Scanner drop leading zeros
Scanner drops leading zero
2 Suggested Answers
  • 251 Answers
SOURCE: How can I zero the information on the scanner to
Hi, to clear the records you will have to download and print off a pdf document which has the scanner codes to delete previous records ( you scan these)
9535M Reference Card.pdf
this is the weblink
http://www.honeywellaidc.com/Site.aspx/eu/en/resources/product_downloads/user_documents/?product=299
Posted on Apr 26, 2010
What is bullet drop at 100 and 300 yds. when zeroed in at 200yds.
my 30/06 drop with 180gran is 1inch zeroed in at 200 yds
Mar 16, 2015 | Optics
Enable Leading Zero in Gryphon M130
Can you show us the printed numbers before going further?
Oct 05, 2014 | Datalogic GRYPHON M130 C Wired Handheld...
Tach. drop's to zero while driving 70 ?
I have had the almost same problem twice. A 'thump', like the engine missed a fire and tach drops. Seems OK after restart. Electrical? Timing chain slip?
Has 135,000 mile. Any clues?
May 15, 2010 | 1997 Buick Park Avenue
Symbol Scanner PDT6846
Contact Stay-Linked support, they should be able to help you pad the zeroes.
They're very much still around, and generally very helpful in my experience.
http://stay-linked.com/
Nov 20, 2009 | Computers & Internet
RPM drops to zero at idling after engine accelerates when warm
This may been an ignition module or a MAF sensor, this car may need to be diagnosed using a OBD I computer code reader to accurately diagnose the problem.
Aug 06, 2009 | 1998 Mitsubishi Eclipse
Voltage Gauge drops suddenly to zero
Charging system grounding out, poss inside alternator
Jan 31, 2009 | 2001 Jeep Cherokee
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Voltage drop test
First, check battery post to cable connection: positive meter lead on battery positive post, negaitve lead on battery's positive cable clamp. Crank the engine and note the reading. A good connection should have zero voltage drop. Second, check the positive cable: positve meter lead on positive battery clamp, negative lead on starter terminal connector. A good cable will show a voltage drop of .2 volts or less while cranking. Third, check the starter connection: positive meter lead on positive battery terminal on the solenoid, negative meter lead on actual starter stud. A good connection will have a voltage drop of near zero volts. Now to check the negative side of the circuit. Total drop on the ground side should be .3 volts or less and can be checked by placing positive meter lead on starter housing and negative meter lead on battery ground post. Take your reading while cranking the engine, and be sure your connection at the starter is solid and clean. If total voltage drop on this side of the circuit is excessive, complete testing at all connections in the same fashion as the positive side of the circuit. Check the following: between battery post and clamp (zero voltage drop), cable end at battery to cable end at engine. (.2 volts or less), cable end at engine to engine itself (near zero voltage drop), and finally between starter housing and engine block (.1 volts or less).
To read the entire procedure for all automotive systems read this artile:
http://www.engine-light-help.com/voltage-drop.html
Aug 31, 2008 | 1997 Chevrolet Blazer
Metrologic Instruments Voyager Hand Held Scanner USB POS (mk9540-72a08) Handheld Logo
441 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
