Question about E-Machines T5212 PC Desktop
E-Machines T5212 machine abruptly restarts every couple of minutes
  • 2 more comments
  • pvlion Feb 02, 2010
    Thanks for the reply, I have had some issues with Emachines in the past...Motherboard on one and power source on the other, so bad capacitors would not surprise me. I was going to open chasse see if maybe heat is building inside and that is causing trouble even though the fans sound like they are performing fine....I will do the inspection and post an update.
    Well, Capacitors are fine with no visible leakage or failure. Lots of Dust, but temperature good inside. ...So now I am...I hate this...doing a Full Format and re-install...Emachines.......
  • joecoolvette
    joecoolvette May 11, 2010
    Some will state that you have a software issue. Corrupted system files, (Operating System) I would like you to check the capacitors on your motherboard, instead. (Computer unplugged from power. Touch the metal frame of the open computer case also, to relieve your body of Static electricity), BEFORE reaching inside your computer) What you are looking for:http://www.capacitorlab.com/visible-fail... Also look for seepage of a yellow/brownish ooze, coming out of the top of the capacitor/s, and/or bottom of the capacitor/s.
  • joecoolvette
    Suspect bad capacitors on the motherboard. Visual signs of capacitor failure,http://www.capacitorlab.com/visible-fail...
  • 30 Answers
This could be due to overheating. Check to make certain all the fans are turning especially the CPU fan. If you are not tech savvy then do not attempt to remove the case cover. Let a professional do it. Messing around in there could cause you to wind up replacing your machine.
Posted on Feb 02, 2010
Testimonial: "Good Comment, I thought the same...too bad it was not to be...b Sad that Emachines are so poor...."
NTLDR is missing
Check your setup settings (BIOS) to make sure your booting from the correct drive. If the computer is trying to boot from the cd drive or USB, rather than the hard drive, you will receive this error message.
Dec 05, 2011 | E-Machines T5212 PC Desktop
Can this emachines T5212 have 4 gb of ram?
Use CPU Z DOWNLOAD it HERE
its FREE and it gives you detailed instructions on your PC. Go to the Memory tab and it should tell you exactly if it has 4GB of RAM or less
Feb 19, 2011 | E-Machines T5212 PC Desktop
Bought a new monitor with a DVI cable but cannot connect this to my T5212 emachines - is there an adapter for this problem?
Yes, there's an adapter for that. You can go to a local computer shop, or Wallmart
thanks
DiegoTech
Nov 13, 2010 | E-Machines T5212 PC Desktop
How long does it take to reinstall window xp on e machine t5212
Approximately 30 to 35 minutes using the Restoration Disk.
Why what's going on?
May 31, 2010 | E-Machines T5212 PC Desktop
Emachines t5212 fax problem
update your drivers for printer fax machine type ..model ..etc
Nov 18, 2009 | E-Machines T5212 PC Desktop
Top Loading Washer stops abruptly at end of spin cycle or when lid is opened.
The ddc may not have been installed correctly. The tranny shaft and motor shaft should be flush with the new coupling gears.
If you laid the machine down to do the repair you caused additional problems with other components.
Apr 21, 2009 | Washing Machines
My dvd wont play any dvds emachine t5212
check to see if the little video wire is hooked up inside to the dvd player.
Apr 21, 2009 | E-Machines eMachines Desktop PC
MISING RECOVERYcdSFIR EMACHINESt 5212
here is how to get the recovery media disk.
use this link I have provided.
here is the link:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Apr 19, 2009 | E-Machines T5212 PC Desktop
Emachine T5212 will not boot up unless operating system disc in used. Get direction to enter boot disc.
Restart, press DEL to enter BIOS and change the boot priority/sequence to boot from your HDD, second choice will be from CD-ROM and last from floppy. Next after saving the changes allow it to boot normally....sodeep.
Mar 21, 2009 | E-Machines T5212 PC Desktop
E-Machines T5212 PC Desktop Logo
195 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
