Question about Dryers
Open dryer door and see sparks - Dryers
    President:
  • 2,468 Answers
If the sparks are near the heating element but it works ok yet,it could just be lint build-up burning up when it touches the element,might want to vacuum it out to lessen the fire hazard
Posted on Feb 03, 2010
Just rebuilt my Frigidaire dryer, new heat coil, temp sensor, and bearing kit, pluged in worked good, opened door and sparked, found i didn't plug in light wire touched, now it won't go, did I blow out the...
Good Afternoon James,
I understand that you rebuilt your Frigidaire dryer, found that you didn't plug in the light wire and it sparked. Now the dryer won't go. From this point, I would suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and see what is causing your appliance to not go. Hope this is helpful.
-Best Regards-
WP
Mar 10, 2014 | Frigidaire Dryers
Dryer door switch sparked and now wont start.
A fuse on the board may have blown....
Jan 04, 2014 | Frigidaire Dryers
What's the problem when a clothes dryer sparks and trip the breaker when you turn it on?
wire is shorting out inside the dryer and could cause a fire !!!
Aug 30, 2012 | GE Dryers
Went to turn on dryer, sparks came out of back of dryer. Dryer will not turn on and inside dryer light does not come on when I open door.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You have a bad connection where the power hooks up...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Kenmore 83142 Electric Dryer
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
Hoover 5020D Dryer door won't open... button is
You probably have a coin or other metal object stuck at the bottom of your dryer door preveinting it from opening. Take a table knife and see if you can push the object upward to allow the door to open..
Jul 29, 2009 | GE DBXR463EDWW Electric Dryer
Loud metal on metal noise, and sparks in rear of dryer
I've seen sparks flying out of an appliance before!
It could be a bad motor so be careful if you plan to plug it in again!
I would leave the back cover off before trying again so as to see what's sparking!
Jan 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire fde336res1
Unplug power immediately.
Check the fuses/circuit breaker at the back of the appliance.
You may need to have the heating element inside the machine tested, and eventually replaced, it had probably shorted out.
You can call a technician using the number listed on the owner manual.
You can get replacements here.
Oct 27, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
