Question about JBL GTO75.4 Car Audio Amplifier
Silver mounting plastic frame (exterior) broke. What now? I need another frame. Where from? Info? Thanks, Chris
  • 47 Answers
YEAH IF U CAN GET AHOLD OF JBL THEY CAN PROB.SEND YOU ANOTHER JUST LOOK UP THEIR NUMBER ON THE NET..COM
Posted on Feb 28, 2010
Instillation in metal door frame
This unit would be mounted in the top of the door and the other sensor above the other they need to b cut in to the door on the top of the door and on the top frame reason being you then have a tamper proof security door that very few will know is a security door to achive this you will need a plasma cutter or hire out to get the holes u need cut thanx Chris
Feb 11, 2014 | GE Sentrol 2707a-l High Security Door...
2001 Ford F150 Extended Cab with broken frame?
replace spring mounts- cut rivets out and replace mounts(use harden bolts) have rotten frame "fish plated" by welding shop
Dec 30, 2013 | Ford F150 Ld Xl/Xlt Model W/O Lightning...
Bowflex Select Tech was dropped and the plastic frame broke. Can it be fixed?
two of the plates have broken, the plastic nipple that holds the plates to the handle have broken off. therefore, the plates do not stay connected to the bar. will bowflex send me new plates? can i send them back and have those plates repaired? or do i have to purchase replacement plates, if so, please share...thanks!
May 16, 2012 | Bowflex Selecttech Dumbbells
How to open Sony remote RM-GD005
1 - Remove the battery cover and undo the two screws.
2 - On the front of the remote down the bottom there is a slider that covers some additional buttons. Slide that down then twist/lift/pull until it comes over. Be gentle.
3- Looking from the top, along each side, between the black front and the silver side pieces, push a small screwdriver in the join to open it up. Start at the bottom and work towards the top. There are a couple of plastic clips along the join and as you work up they will unclip. Once you have done one side you should be able to pull it apart fairly easily.
:) Chris
Jan 15, 2012 | Sony Televison & Video
NEED TO REPLACE THE EXTERIOR DOOR HANDLE
HAVE TO REMOVE THE DOOR PANEL REMOVE ALL EXTERIOR OR VISIBLE FASTENERS AND MOST DOOR PANELS HAVE PLASTIC CLIPS ALSO SECURING THEM TO THE DOOR FRAME.ALSO ANY ELECTRICAL WIRING INTERFERING WITH PANEL REMOVAL. THEN ACCESS THE TWO NUTS/BOLTS ATTACHING IT THE THE DOOR FRAME. THEN REMOVE THE RODS ATTACHED TO THE HANDLE GOING TO THE LATCH/LOCKING MECHANISM AND REVERSE THIS PROCEDURE FOR INSTALL.
Oct 06, 2010 | 2001 Toyota Camry
Replacing my headlamps on my 96 Chevy Tahoe
On a 99 Tahoe Don't remove the grill.. There are two 6 inch long, hex head, vertical screws protruding from the frame above the headlight. To unscrew use a small hex socket.. maybe 1/4 inch. Turn the screws counterclockwise to remove till loose then pull up. The screws serve as a linch pin to secure the headlight to the mounting bracket. Here's a pic of the driver side light. Also, I had very good results with my park light lenses in 5 minutes with a hand drill, a soft buffing pad, and some fine polish. They were yellow and dull and looked clear and white when done. I washed the inside of the lense with soapy water and a soft toothbrush.. it made a big difference.fcb90cc.jpg
Mar 04, 2009 | 1996 Chevrolet Tahoe
Delonghi fryer
I broke the plastic mount that holds the controls against the outside of the frame. That plastic mount was depressing a switch that is no longer being depressed. I get an Error message too. I'm going to try to contact the manufacturer to see if I can get a replacement part. (I doubt I can because the model is discontinued).
Aug 02, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
JBL GTO75.4 Car Audio Amplifier Logo
54 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
