Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
How to set master, slave settings in sata hdd
I got 2 hdd and i want one as master and other as slave . so , plse tell is there any need to change the bios settings or any other adjustments. for this./.........
  • 115 Answers
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Posted on Feb 02, 2010
Can not detech
Good day!!!
please check the HDD itself if it is set on master?slave?
please change it to master..
if the problem persist just add a comment.
Jul 11, 2011 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before)...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
May 18, 2011 | Computers & Internet
I have connected my 300 gb sata hdd to my pc which already has a 160gb sata hdd set to master when i start up my pc they r both set to master but i am told sata hdds dont have master / slave settings
They don't have master/slave settings as only one SATA drive can connect to a controller, however some BIOS have a setting designed to facilitate older OS's like XP that don't always have drivers available for the newer SATA RAID controllers built into most mid to high end PC's. If this setting is enabled on your PC then they would look to windows like a pair of master IDE drives on a Primary and Secondary IDE Channel even though each has it's own dedicated controller.
Sep 21, 2010 | Western Digital Hard Drive
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
IBM THINKCENTRE A51p WIN XP PRO/SP3 1GB RAM ALL MICROSOFT UPDATES ARE CURRENT BOOTS QUICKLY WITH 1 SATA HARDDRIVE (1.5 MINUTES) BOOTS SLOWLY WHEN 2ND SATA IS ADDED (5 MINUTES) ONCE WINDOWS...
it seems as they are conflicting this u usually caused by jumper settings you need to download the utility program from the hdd manufacture the utility allows you to change hdd priority you need to change the settings on the second hdd to slave and the first hdd to master but like i said unlike ide which has jumpers sata has digital jumpers the utility from products website is needed for this
Sep 02, 2010 | IBM ThinkCentre A51 PC Desktop
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
NO CHART ON IT TO TELL ME HOW TO JUMP IT SO IT KNOWS WHETHER OR NOT ITS THE MASTER
PATA HDD's (the ones that take the ribbon cable) have had the jumper settings printed on the label for the past 10 years. Different makes have different settings so we would need to know the make and size of HDD.
You could also use trial and eror without damaging the HDD.
SATA do not have jumpers as they are "cable select" and master is normally the one in the first SATA connection on the MoBo
Dec 17, 2009 | Compaq Computers & Internet
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
1,156 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
