Question about Music
I have a Thomas Symphony Royale 782 with the rack portion of the rack and pinion volume control broken. Where might I find this component?
  • 1 more comment
  • Warren Godfrey Feb 03, 2010
    Thanks for the response, but it is strictly a mechanical problem. One end of the piece I need has a pivot point that bolts to the outside edge of the volume pedal at it's top right hand corner. I would guesstimate the remainder of the piece to be about 5 inches long (I don't have all of the pieces from the old one.) It is slightly curved and has teeth on the underside that mesh with the gear mounted on the end of the potentiometer shaft.
    As a retired woodworker, if I can't find the actual part I will have to fabricate one from maple using the bandsaw. I would much rather have the factory part though if at all possible. The plastic won't move when there is a change in humidity or temperature.
  • Warren Godfrey Feb 04, 2010
    The brass rack & spur gear seems like it could be the perfect solution, but I'm curious as to how much of a bend the rack will take without distorting the meshing of the rack and spur gear. The one piece that I have left of the original rack is long enough to calculate that the arc it presents is one created by a seven and one eighth inch radius at the crown of the teeth (teeth are on the outside of the arc). Is it reasonable to expect that one could bend a section of the indicated rack to such an arc without adversely impacting the meshing of the two pieces?
    I also meant to correct a significant typo on my original inquiry, not that it means a lot at this point, but the Model # of the Thomas is a Symphony Royale 871 not the 782 indicated. Also, I would hope that there is a range in diameters of the spur gears for any rack. The organ is not where I can measure it right now, but I believe that the gear currently on the shaft has a diameter around 1 1/2". Obviously the diameter is important in terms of the number of revolutions the potentiometer shaft will take as the rack travels it's entire length.
  • Music Master
  • 5,603 Answers
If it is the potentiometer that is broken, it is likely an AllenBradley "J" style pot.
Here is Digikey site for J pots. Choose resistance to match. You may need to check if it is an audio taper as well. The site should have them as well.
http://search.digikey.com/scripts/DkSearch/dksus.dll
Posted on Feb 02, 2010
Testimonial: "I do believe that this appears to be an excellent solution to the problem. The input was invaluable and I really appreciate the fast response."
  • 1 more comment
  • Fred Yearian Feb 03, 2010
    I was afraid that it MIGHT be the gear rack. Making one of maple will NOT hold up to the wear of the gear.
    Now here is what we do: You can buy gear rack, including brass,
    Example: http://www.qtcgears.com/KHK/index_Racks_...
    I would probably select the BSR1-300 which should be about 12 inches of 8 teeth per inch...(dimensions there are metric) I would also get a spur gear to match from them with a 1/4 inch hole or one you could modify to fit the pot.
    The brass rack you could warm with a propane torch and curve a bit as needed. You could drill or attach it as needed.
  • Fred Yearian Feb 04, 2010
    The brass rack could be thinned in depth a bit and sometimes one can make cuts to allow it to bend a bit... Heat of course would help it bend. There are other options on the site, however they all seemed much longer and more expensive.
    Yes, the total travel number of teeth and the diameter of the gear is important to get close.
    Two more ideas:
    http://www.goldmine-elec-products.com/pr...
    This is a 5 inch gear... MAYBE you could cut it down to make the rack?
    Next idea is to use a ladder chain and sprocket with a spring.
I plug it directly into my pc and it wont record on my music programs.Does this mean it is broken?Is there something im missing?.And it was purchased new but came with no directions,is that right?Also...
There is no volume adjustment. You would have to use the volume controls in the PC "control panel". Not all PC's will be compatible with this mic, as this mic is monaural, not stereo. You may have to use a 1/8 jack monaural to stereo jack/plug for the mic. Be sure and set the volume levels for both the mic and headset in the control panel AND UNMUTE the mic.
May 07, 2011 | Yamaha Cm500 Headphone With Built-in Mic
I have a Peavey Bandit 112 amp that takes between five and ten minutes to warm up. It use to come on right away. any suggestions?
Take it for repair immediately as there is something that is thermally sensitive and it may cause worse damage with continued use. The problem is LIKELY a broken solder joint. Depending on where it is, it could cause damage to the power amp portion. It OFTEN is at one of the leads to a volume control and those USUALLY don't cause damage, but one can't be sure till it is repaired. These broken joints oxidize and then eventually warm and punch through and the device starts working. You MIGHT want to try wiggling the controls to see if one brings the unit on immediately showing itself as the culprit.
Apr 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a marshall vs100 combo, the problem is sometimes it will work great for weeks on end, and then it decides is wont anymore I get a loud sort of rumbling noise, volume reduction and finally no sound...
Intermittent problems like this are hard for the shops to find... the thing will sit for weeks and work while on the bench.
This does have a tube in it, and I am sure that has been replaced, but that is the first thing to replace as the heater in them can break mechanically and come on and off causing intermittent operation.
The next thing is a visual inspection. It takes a trained eye to spot things like cracked circuit boards, broken leads into vilume control pots, and bad solder joints.
You have spent too much so far so this is what I recommend for you to try... It is DIY. Remove the amplifier and take a small soldering iron and some electronic solder (rosin core) and resolder EVERY connection on the board. Trying to have you check the joints is hard to describe other than looking for a tiny grey line on the meniscus of the solder fillets.
Next, get a very bright small LED flashlight and light the backside of the board looking for cracks. Look especially near mounting points of the board AND heavy components like electrolytic canned capacitors.
Look for resitors or components that might be cracked.
Look for areas where the board seems to have heat discoloration marks.
Look for connector problems. The input jacks and the soldering around them are often a problem. Jacks that have switches that allow preamp and access to the power amp OFTEN have poor contacts on the switches that oxidize or get loose.
Remember the vacum tube portion of this runs at high voltage so unplug the unit for a bit before working on it.
lastly, with the unit operating, take an insulated stick and do some poking of components and putting pressure on the circuit board. This looks for marginal component connections and cracks in the circuit traces... one listens for the least scratchy noise in the sound... you dont need audio going through for this test.
Sep 09, 2010 | Music
My marshall classic reverb 30 makes sound some times and some times when you play with the volume knob it stops
The volume control knob PROBABLY is broken, dirty or has bad soldering to the circuitry.
Use some CRC226 in the control if dirty. While you have the unit apart, check the soldering and for any circuit board cracks.
Feb 21, 2010 | Marshall Music
The volume control is not working... even when the volme is "off" it is still on
Chances are the resistance element in the volume control has broken. This is COMMON if the control knob gets smashed some way.
A less common thing would be broken solder where the control is soldered to the circuit board. This would be obvious once the board is accessable.
Servicing involves removing the chassis and replacing the potentiometer.
Jan 17, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
I have the washburn wi65 pro and the volume is 100% from 2 to 10 and 0%-99% from 0 to 2. how can i fix that?
The probable cause is either one end of the volume pot is broken, or the wire to it is broken. Test the control and wiring with an Ohmmeter.
Jan 10, 2010 | Washburn X10 Electric Guitar
Volume problem
Sounds like a thermal problem... Search suspected areas in the amplifier portion with circuit cooler until you find a bad component.
Dec 09, 2009 | Yamaha Music
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
Its a tele style guitar and its as if the volumn and tone controls are intermixed. they both have to be down to silence all sound. humbuckers front and rear three position switch. are jb player all...
Possible problems include defective volume control or broken wire OR improper wiring.
Volume controls can have a broken resistance element and fail to go to zero volume.
Oct 30, 2009 | Jb Player Music
Need help connecting Korg C-303 (Concert Piano) and Korg Symphony Model O3 (Orchestra Module). Have no documentation for the Symphony module.
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
May 12, 2009 | Music
Music Logo
159 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
