Question about Canon Cameras
Problem with canon powerShot SX100IS: when i start to make fotos, it shuts down and i see the message: change batteries,i put new one, it does the same ( sometimes after one or 2 photos) ! why?
  • 77 Answers
I would recommend using rechargable batteries, that are at least 1800 mAh. If you use non-rechargable batteries, i would recommend buying energizer lithium- they are more expensive, but worth it because they last much longer.
Posted on Feb 02, 2010
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
What is the maximum size sd card can i put in my Canon Power shot SX100IS
SD cards max out at 2GB. The SX100IS can also use SDHC cards, which max out at 32GB.
Jul 22, 2011 | Canon PowerShot SX 200 IS Digital Camera
IT KEEPS TELLING ME TO CHANGE THE BATTERIES (EVEN WHEN THEY'RE NEW BATTERIES) AND SHUTS DOWN COMPLETELY.
Couldn't find a firmware upgrade for my Canon PowerShot A720. Tried putting a piece of rubber under the spring on the lid to make it tighter and it helped because I can take more pictures before I get the dead battery message (even thought they aren't dead). I bought the Duracell that you can check the charge on because I'm sure I've wasted dozens of batteries by now.
Aug 31, 2010 | Canon PowerShot A720 IS Digital Camera
What is greatest dpi for PowerShot SX100IS?
Yes your camera will give images with 300dpi . You need to set the dimension as 3264 x 2448.
Hope this helps.
Jan 30, 2010 | Canon Cameras
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
New batteries are not accepted
put batteries in very carefully - not bouncing them in. If you get the 'change the batteries message' then open the battery cover turn the camera a little gently to reposition the batteries and hopefully it should go away. Test your charger too ... is it charging? is it the same thing with non-rechargeable batteries?remember Batteries don't work well when cold this could cause the camera to shutdown. It might also be that the auto shut down setting is too short unless it is shutting down while you are actually shooting.make sure you are using the correct battery type and match.clean the contacts in the battery compactment.hope this helps
Sep 06, 2009 | Canon PowerShot A430 Digital Camera
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Cameras Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
