Our infrared remote control receiver is making a buzzing sound & the unit will not run on any cycle it's an airwell
    Problem Solver:
  • 7 Answers
Did you or anybody changed something in the indoor unit?
Normally when the unit is making a buzzing sound, the model plug is mounted the wrong way on the electrical board.
Posted on Aug 10, 2010
  • patfullerton Jul 22, 2011
    I have the same problem with my airwell unit. Did you find the problem?
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
Mar 09, 2013 | Sony STR-DE875 Receiver
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Kodak carousel makes a buzzing sound and will not advance
Your problem is most likely related to cycle contact adjustment. See the attached illustration for the parts involved and the SPECIFIC POSITION of the contact parts:
Sep 08, 2012 | Kodak Carousel 4400 Slide Projector
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
I can not make connection between the remote control and the screen.the screen functions oke
SOUNDS LIKE THE INFRARED SENSOR ON THE SCREEN IS FAULTY,YOU CAN FIT AN EXTERNAL SENSOR AND MOUNT IT ON THE DASN AND WIRE INTO BACK OF SAT NAV UNIT EASILY.
Apr 09, 2011 | Blaupunkt DX-V GPS Receiver
I recently bought a NR1501 receiver and a CD5004 CD player at the same time. I don't use the tuner as I have a separate DAB radio. I use the Aux2 source for the radio input and the CD source for the CD...
How did you isolate it to the CD player?
Of course you know that this fault lies in the realm of the Twilight Zone as no 'intelligence' or commands are exchanged between the units via their RCA cables.
http://www.retrevo.com/support/Marantz-NR1501-Receivers-manual/id/23506ag717/t/2/
I'd try to eliminate the posibility that erroneous remote control commands are getting into the receiver from somewhere, either your own remotes or some other I/R source. Block the I/R sensor on the receiver and see if it switches spontaneously. You may haved a rogue I/R source in the room.
Do not allow direct sunlight, an inverter fluorescent light or other strong source of light to shine onto the player's infrared receptor window. Otherwise, the operation of the remote controller may be disabled.
• Bear in mind that operating the remote controller may cause other devices operated by infrared rays to be operated by mistake.
• The remote controller cannot be operated if the space between the controller and the player's infrared receptor window is obstructed.
• Do not place any objects on top of the remote controller.
Doing so may cause one or more buttons to be held down which will cause the batteries to run down.
Jan 20, 2011 | Marantz NR1501
Dish remote quits working at 7pm.
Is this issue with an IR (infrared) remote which is generally for "tv 1," or is it a UHF remote which is used commonly used for, "TV 2?" It sounds as though there may possibly be something interfering with the remote signal & strangely around the same time everyday! IR remote signal interference can be caused by other electronics that may be running & within close proximity of your DISH Network receiver. A way to determine if this is in fact the issue would be to power everything off but leave the receiver & your TV powered on. You would then proceed by powering one component on at a time, & then test a remote function after each component has successfully been turned on. Hopefully this process will help you when trying to determine if it is in fact a component that is causing interference and as a result the remote appears to stop working around 7pm. I Hope this helps you! If this doesn't resolve the issue, please feel free to contact me directly at any time. My e-mail is, Kirstie.filosa@Dishnetwork.com.
-Take care,
Kirstie DISH Network
Oct 04, 2010 | DISH Network IR Remote Control
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
I can not get my Sony RM-P501 to control my receiver. It was working perfectly but suddently it does not control the receiver. Seems like it lost the factory programed features
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
Jan 01, 2010 | Sony RM-P501 Remote Control
LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Dec 05, 2009 | LG 42PC3D 42 in. Plasma Television
Heating & Cooling Logo
237 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
