Question about HP Officejet 4355 All-In-One InkJet Printer
Hp4355, print cartridge does not slide to the right side when i open the cartridge door.. pls help
  • 115 Answers
Its need to servicing, because your cartridge cradle is going jam.
Regards
Ashly
Posted on Feb 02, 2010
How do i change the ink cartridges for the photosmart 7960
Make sure the printer is ON.
2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place.
The print carriage moves to the far right side of the printer.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector. For more information, see Use the print cartridge protector. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge. The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used print cartridges free of charge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.
8. Close the print-carriage access door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 15, 2013 | Office Equipment & Supplies
I no longer have my manual, how do I change the ink cartridges for the HP Officejet 6300 all-in-one?
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
slot on the left.
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
12. Press OK.
Jul 17, 2011 | Computers & Internet
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    Change ink cartridge
    1.
    Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
    The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
    slot on the left. If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
    4. Pull the print cartridge towards you out of its slot.
    5. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
    6. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place. If you are installing the tri-color print cartridge, slide it into the left slot. If you are installing the black print cartridge, slide it into the right slot.
    7. Close the print cartridge door.
    8. Close the print cartridge door.
    9. Press the Scan button. The product aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
    Apr 26, 2010 | HP DeskJet F4280 All In One Printer InkJet
    Ink is stuck in the printer. I can't get it out.f4280 deskjet
    I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
    http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
    1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
    1 Print cartridge slot for the tri-color print cartridge
    2 Print cartridge slot for the black print cartridge
    6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
    1 Copper-colored contacts
    2 Plastic tape with pink pull tab (must be removed before installing)
    3 Ink nozzles under tape
    7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
    Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
    How do i install ink cartridge for HP 4355?
    To install the ink cartridge
    1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
    2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
    3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
    Important : Do not touch copper-colored contacts or retape the cartridges.
    4) Insert the tri-color print cartridge.
    Caution : The device must be On before you can insert the print cartridges.
    a) Slide the tri-color print cartridges into the left slot.
    b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
    5) Insert the black print cartridge.
    a) Slide the black print cartridge into the right slot.
    b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
    c) Make sure both cartridges are secure, Close the print cartridge door.
    6) Align the print cartridges.
    a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
    b) Remove the alignment page from the output tray.
    c) Place the alignment page face down into the document feeder.
    d) Press OK to scan the alignment page.
    After the page has scanned, alignment is complete.
    Hope this helps. Please rate my response.
    Thanks
    Have a good day.
    Dec 01, 2009 | HP Office Equipment & Supplies
    Streaking
    Replace toner cartridge . Must be originals
    Jun 17, 2008 | Dell 3010cn Laser Printer
    HP Officejet 4355 All-In-One InkJet Printer Logo
    81 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
