Question about Sewing Machines
I have one usha ordinary machine,the upper part of the machine is not rotating,it takes too strength on the stand,i cant stich,wat i do?
Stitch is not coimg properly on thick places like bottom parts and thread is cutting in thick cloth place,what to do
Posted on Mar 01, 2010
My Usha janome allure machine is not giving stitches. And the thread curdles below.
bottom tension is not correct take bobbin out and rethread it HOLD both upper and lower threads tight . when first starting to sew
Feb 09, 2015 | Janome Sewing Machines
Usha flair model
If you check on your machine, there will be a switch or dial (depending on model) that also has a blue color. That is probably for stretch stitching. You will have to change the switch or dial to the stretch stitch setting and then you will get those stitches. No need to change the needle plate. You will only need to change to a ball point needle if you are stitching on knit. Otherwise a regular needle will be fine.
May 03, 2014 | Janome Sewing Machines
Install dell wireless 5530
machine out of time. theres a mark on needle bar that aglins with the needle bar guide. when u have the needle in this position u have to loosen the hook ( 3 screws) and place the point of the hook just meeting the needle. before u try this try lowering the needle slightly.
Mar 17, 2014 | Juki Sewing Machines
I have a janome 8050 sewing machine. It has started making loose stiches underneath and making a noise. I have changed the needle, bobbin, thread, cleaned the bobbin area. It will not make any stiches at...
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Apr 08, 2011 | Janome Sewing Machines
I hv usha flora sewing machine.. when i try to stich silk clothes i set my machine for the stiching by the given nob.. but then also the machine does not function properly i mean there is no lock-n-lock of...
Are you saying that the stitches are not locking and that you can pull the thread out easily from the seam?
If so, its a tension issue, check that the bobbin thread is clicked into the tension spring, when you pull on it it should be firm but let you pull it out gently.
Check that you have a new sharp small needle in, size 60 or 70 for silks and flat shank to the back. Push it fully up into the needle holder and do up the needle thumb screw.
Rethread the machine, and test sew again.
I hope this helps you a little. Your machine model is not available in my country but this is general advise for all machines.
Mar 09, 2011 | Sewing Machines
Hi FixYa team, I need a Manual for USHA Janome Wonder
www.mouthshut.com/.../Sewing_Machines_reviews-925345.html
Jun 19, 2009 | Janome 6019QC Mechanical Sewing Machine
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
118 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
