Question about Goodman Heating & Cooling
HAVE A BRAND NEW GKS90904CX FURNACE. IT RECYCLES EVERY 2-3 MINUTES.WHAT WOULD MAKE THAT HAPPEN?
    Genius:
  • 1,400 Answers
Hello
In the thermostat is a anticipator which controls the cycles.
Either the anticipator is set wrong or the thermostat is bad.
Posted on Feb 02, 2010
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Tip
Gas Furnace Repair - Steps to Troubleshoot the Problem Yourself
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your gas furnace is not heating. You know that is has power because the lights are blinking showing you some kind of weird code. But it is getting colder by the minute and you wonder if there is anything that you can do. Here are some basic things that the homeowner can check.
The lights blink a crazy combination of on and off sequences. The furnace is trying to talk to you. The problem is that you don’t understand the language. The language of the furnace can be very confusing if you do not know what the problems that the furnace is trying to tell you through the flashing codes is.
Before running to the phone to call the heater guy to decipher the codes there are some thing that you should check. First and most important make sure that the power is on to the furnace. If there are no lights flashing on the circuit board that is a good indication that you probably have a power problem.
Now that you know that there is power, recycle the power on and off. This will often reset the brain of the furnace and wipe out the problem so that it will try to go through the startup cycle again. If the problem was temporary, like low voltage, or low gas pressure the furnace may light up and be fine.
If the furnace stops during the lighting cycle then you may have other issues and will need to look into the problem further with the help of a professional. Of course you need to make sure that your flue is not blocked or that the filter in the furnace is clean. These things are common causes of problems and can easily be fixed.
These are the first basic steps to trouble shooting your furnace problem. To check out the problem further you may need some specialized tools to find out where the problem lies.
Make sure that you at least try these things before calling a professional to save yourself the expense of a service call that is only a couple of minutes long and makes your feel like you are paying the guy to bush a button and run again.
Believe me when I tell you this. There have been many calls that I have had that were just a matter of recycling the power and then leaving the bill. Do not let this happen to you!
on Dec 03, 2009 | Heating & Cooling
Furnace fails to run, hearing a continuing clicking sound, but no flame
This sometimes happens when gas supply may be low. Try turning off your master switch and then back on to recycle the igniter circuit. If it continues, call you service representative.
Mar 23, 2015 | Heating & Cooling
Ruud furnace 2 blinking green light
The ventpipe heat limit, fan limit, and chamber limits are only a few of the safeties that turn a furnace off when something is getting too hot. I recommend a qualified technician have a look at it.
Nov 28, 2013 | Heating & Cooling
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
I have a goodman mfg gmp100-4 furnace. When I turn theromsat to heat I hear blowing for sixty seconds but that is all that happens. What should I check first?
Your furnace has a combustion blower on it. If it runs and don't pull in the vacuum switch the furnace will not start. On the combustion blower you will find a little rubber hose follow that hose to the vacuum switch. You will see 2 wires on the vacuum switch connect the 2 wires on the vacuum switch together. If your furnace starts and runs fine for 15 to 20 minutes you need a new vacuum switch. Try this first
in this image A is vacuum switch B is combustion blower
Hope this helps......
Nov 16, 2010 | Goodman Heating & Cooling
Inspection troubles
If you google the make and model number you should pick up the company website where you can down load a manual .You may also find a tech helpline they will give the right size flue .
Mar 23, 2017 | Goodman Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
