Question about Dishwashers
I dont have the manual for the BEKO DWD 8650x dishwasher. The light for rinse aid is currently on - do this mean I need to top the rinse aid up? and how do I know how much?
There is a switch to flick behind the numbers wheel - this is located next to the dishwasher tab dispenser on the inside of the door. G
Posted on Feb 28, 2010
What can be causing trip switch to trip via a Beko DWD 5410W
You mean tripping the circuit breaker?
Can be a sloppy or worn breaker. Does it positively click shut, or does it creep over under load?
Could be water dripping on the motor.
Could be a motor that is seizing and drawing too much power.
The instructions are here, which includes limited troubleshooting a details on servicing.
http://downloads.beko.co.uk/bekoupload/manuals/DWD5410.pdf
Dec 11, 2015 | Beko Dishwashers
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
What do the Tecnik dishwasher symbols mean? I have a unit not working with a warning light on I cant find in the manual.
The little star means you've run out of rinse-aid. See the flap that's next to your tablet dispenser, it has the same star on the lid, inside there you can refill the rinse-aid by pouring it into the tiny gap next to the dial! The dial setting allows you to change the flow of rinse-aid...the light will then go off. However, I've yet to find out what the light with the two directional arrows means! Ill post when I know!
Mar 12, 2011 | Dishwashers
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Aug 31, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
219 people viewed this question
Top Dishwashers Experts
Owen Barnes
