Question about HP Laser Jet Printer P3005dn
How do you replace Face Down Delivery Roller?
How do you replace Face Down Delivery Roller on the HP Laserjet P3005?
    Genius:
  • 1,089 Answers
Remove the left, back and top covers.
At both ends of the shaft are plastic bushings.
Rotate them so they point in a horizontal position.
Lift the right side of the shaft(it has a white gear on the end) and then slide the shaft to the right to release the left side from the chassis.
Posted on Feb 13, 2010
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
Apr 14, 2014 | HP LaserJet P3005 Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
P3005 13.05 error only when duplexing Lead edge stops at but not in fuser rollers Fuser has been replaced no odd noises
While going back, the paper not grabbing properly due to paper out roller got warn out, just file and make it rough on the surface, problem will solve.. You can see the paper out roller where paper coming out..
Jul 19, 2011 | HP LaserJet P3005 Printer
I have problem with hp laserjet p3005 with paper jams inside fuser assembly, i already clean the rubber roller then still the same problem occure...please someone help me.....sorry for my bad english
If you are getting jams in the fuser, then there may be paper stuck in there, or the roller sleeve is damaged or the drive gear could be bad. You are going to have to take the rear cover off to look at the fuser.
Someone trained is going to have to remove the fuser to inspect it.
Jul 13, 2011 | HP LaserJet P3005 Printer
How to remove and replace a printer roller on HP Laserjet p3005
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
Dec 28, 2010 | HP LaserJet P3005 Printer
My HP Laserjet P3005 is almost 2 years old and needs a new fuser assembly. Is this normal? How much should this cost? Would I be better off buying a new printer
Hewlett Packard P3005 Fuser
The HP P3005 fuser is located at the back of the printer.
The fuser is suppose to last up to 200,000 pages, however they rarely get that far.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Dec 07, 2010 | HP LaserJet P3005 Printer
Hp 3005dn prints blank pages, even the configuration pages requested from the machine itself
if you haven't any error message then you may have a problem in laser shutter, check and reseat your catrtidge, or you have a problem in your DC Controller
Apr 01, 2010 | HP LaserJet P3005 Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
HP Laser Jet Printer P3005dn Logo
Seeker5211
Seeker5211
