Question about Dell Latitude X1 Notebook
Latitude x1 is plugged in to the mains, yet the battery doesnt charges and the laptop turns itself off
  • Dell Master
  • 12,061 Answers
Your battery is faulty. You need a new one.
Posted on Feb 02, 2010
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
I have two latitude x1.one dosent charge the betry.i have to put charged betry in it and its work fine..i need to fix this.anyone can help me?
Try another Cord/charger with the EXACT same power specs as the Original. Both Batteries are good? Both Cord/Chargers are good, same power specs. DC volts and Milliamps? Dell Specs: http://www.dell.com/downloads/emea/products/latit/LAT_X1_emea.pdf Battery, charger can be found here: http://www.atbatt.com/laptop-batteries/b/dell/m/latitude-x1.asp
Feb 27, 2013 | Dell Latitude X1 Notebook
Got a dell latitude d520 charges battery ok will not power up with mains plugged in only works on battery power any ideas
Hi there!
Your laptop is working with just the battery but not with the main power. This issue you have here is usually caused by a motherboard problem but have you tried to remove the battery then try to turn on computer? If it works then you might just need a BIOS update for the computer of not then there's a high chance that the motherboard your using is having a problem using the main source.
Hope this helps!
Sep 07, 2011 | Dell Latitude D520 Battery PC Notebook
How to replace battery for a Latitude X1
The Dell Latitude X1 laptop has a 53 WHr 6 Cell Lithium Ion Battery. Your safest bet is to purchase a replacement battery from Dell directly, in order to avoid confusion and mismatched parts. The Dell Part number for your battery is Dell Part# : 312-0342. The Manufacturer Part# : Y6457. The cost is 135.99 from Dell directly. While you may be able to find a battery elsewhere for cheaper, it is not recommended.
Good Luck,
NOLA Tech
Jan 28, 2010 | Dell Latitude X1 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Dell Latitude X1 will not power up
This is a common problem for all laptops.
The issues you're experiencing all point towards a bad motherboard.
There is very little that you can do yourself other than trying to boot the computer with no battery and reseating the memory.
Try these two options first, write back, and then we'll proceed from there.
Mar 01, 2009 | Dell Latitude X1 Notebook
Dell c640 not charging battery
I have found a few things with this model, first if the laptop works on ac power when the battery is out then try pushing the button on the battery itself and see how many lights light up. If they are not green replace the battery it just wore out. Second if you can wiggle the power cord and you see the charge light flash on and off then the solder joints are cracked on the main board and you will have to take the main board out of the case and drill out the 3 rivets on the metal bracket covering the plug and bend it out of the way then there are a small brown and a small black block near the plug resolder the ends of these facing the plug. bend the bracket back into place and epoxy it where it was. put the main board back in the case hook all the stuff back up and now it will charge your battery. If you are not good at this stuff I would not try it yourself. I have fixed 2 c640s this way and it is slow careful work.
Jun 24, 2008 | Dell Latitude C640 Notebook
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Dell Latitude X1 Notebook Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
