Question about Whirlpool Dishwashers
Whirlpool ADG993 Dishwasher Start light flashes continuously
SOURCE: Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
Posted on May 22, 2008
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: Clean light on dishwasher won't stop flashing
Reset worked for me. I had the same problem as others. Thanks for your help.
Posted on Nov 10, 2008
  • 58 Answers
SOURCE: Whirlpool dishwasher clean light flashing
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
Start light flash 2 times on a Whirlpool ADP 6940.
Whirlpool dishwasher start light flashes 7 times repeatedly and wont start
May 24, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Have a Whirlpool Dishwasher 6ADP 5540. Starts cycle - fills water then about a minute into it the start buttons flashes 6 times and will not continue on. Very rarely, the cycle does continue on. Have...
Hi Jodie,
An F6 fault code - indicated by the green light flashing in sequence next to the start button - is indicative of a water inlet problem.
First of all check that the water tap the dishwaher connected to is fully open. If this does not work check that the feed pipe from the water source to the appliance is not blocked.
If neither of these two things are the problem then you will need to order a new flow meter/ reed switch and this will sort your problem out.
The Whirlpool UK spare part number you'll need is 481241868368
Hope this helps
Alex
Jan 14, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
How to reset whirlpool dishwasher adp4501/5
whirlpool dishwasher problem adp 4501 - I had a problem with this machine not starting properly, hunting, with the start light flashing apparently continuously the pump also going on and off in time with the flashing.
After looking around a number of forums I cleaned out the sump gently with a sponge which did not help, then followed this up by pouring a kettle of boiling water into it. This had no immediate effect, but after a few hours the machine started and ran properly again.
Cost no money and saved me the hassle of taking it out and stripping it down - well worth a try.
Jul 26, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool ADP4400 the green light is flashing and the pump continues to pump but the cycle will not start
I had this exact problem with my dishwasher but i managed to fix it today. It was such a simple problem, the water outlet pipe had a kink in it and wouldnt let the water drain. I straightened the pipe, put duct tape around the kink to strenghten it and the dishwasher worked straight away. I hop this helps.
Apr 28, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 | Dishwashers
Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Jun 11, 2007 | Whirlpool 24 in. GU2548XTP Built-in...
Dishwashers Logo
449 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
