Question about Compucessory Computer Data (11400) Networking Switch
How to change the hard disk to act as a master, slave
  • 12,061 Answers
There are Jumpers on the drive Master & Slave settings usually printed on the drive. There is another less common way this is via a Cable..called cable select.
Posted on Feb 02, 2010
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
How to set drive for slave function and master function
You can change the jumper settings near to the data cable port to change the master slave settings on most of the HDDs. Most probably you can see the labels near tot he jumpers itself to change the master slave settings. You can see the below picture for reference.. please set that according to the label near to the jumper pins..
Jan 12, 2011 | Maxtor Hard Drive
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
How to make master and slave
"Now for a refresher course on hard drive connections. When connectingmore than one hard drive to a computer on the same IDE controller, yougenerally have to assign one as the primary (master) and one as thesecondary (slave). You do this by changing the jumpers on the harddrive next to the power connector. Normally, the drive will have adiagram to let you know which jumper should be set for a master driveand which to set for a slave drive. You'll notice in the picture belowthe jumpers are circled on the end of the drive and the top of thedrive shows the diagram to follow."
Go here http://www.pchell.com/hardware/masterslaveorcableselect.shtml for more..
Dec 06, 2009 | Computers & Internet
External hard disk problem
Yes, it is very easy solution.
Just change your jumper settings, kindly set jumpers as a slave drive I assure that your Hard disk will be shown in drives.
Goo Luck
Nov 25, 2009 | Computers & Internet
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Hard disk
you have to have both drives share the ide cable.on the back of each drive you will see a jumper,you will also see markings cs,mas,slave.the drive you want as master use the jumper on cs (cable select).the drive you want for slave use the slave jumper.if you just want to use your new drive put the jumper to cs first if that doesnt work put the jumper to master.
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
Compucessory Computer Data (11400) Networking Switch Logo
96 people viewed this question
Top Compucessory Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
Are you a Compucessory Computer and Internet Expert? Answer questions, earn points and help others
