Goodmans DVD writer/player (GDVDR319)
Its power bourd was initially damaged by general set. I changed its damaged capacitor and it work for about 3 week before the same capacitor burn again. Then, I try to replace again and repeat the same thing.
    Genius:
  • 2,785 Answers
Check it with an qualified person
Posted on Apr 02, 2008
Auto tuning digital tv lcd
i cured the buzzing by replacing the 120uf/450v capacitor on the power board (the biggest one on there )
Dec 29, 2013 | Goodmans Televison & Video
32MD251D/37 will not power on
Zack Corpier
Workup for repair
02/22/2013
Diagnosis for Magnavox 32MD251D/37
Symptoms:
Will not power on
Once on, if turned off power might not return
Does not respond to power cycling
Possible Culprits:
Overloaded fuse
Damaged/fried power board
Damaged/fried inverter board
Damage to wiring or related
Overloaded capacitors on power board - I identified this based on a visual inspection and a multi meter test
https://lh6.googleusercontent.com/-Mcf67G5l3l8/USgitModWZI/AAAAAAAACRo/PwjueC45Hjo/w333-h319-o-k/caps.png
Problems Identified:
Capacitor 2079 appears overloaded - 1200uf 35v
Capacitor 2080 appears overloaded - 1200uf 35v
Explanation:
The capacitors referenced regulate the voltage controlling the power. These caps have a limited lifetime in hours which is usually around 3000. The device was left on for an extended period of time overloading these essential components.
Resolution:
1. I will order a set of replacement capacitors
2. Discharge board prior to work
3. Remove and replace damaged capacitors
Required Parts (total cost $30):
(2) Vented axial 1200uF 35v Capacitors - $8
Variable wattage soldering iron (minimum 35w) - $22
Feb 10, 2013 | Magnavox 32MD251D/37 Tabletop Pedestal...
DVD door will not open
the litle belt downside of the tray change it
May 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Cant get onefor all urc 3426 to work with tv or dvd.
i have a a goodmans gdvdr319 but i lost the remote for it got a one for all remote urc-3426 and i have put in some code in but stikl not work
Jan 15, 2009 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Hi I bought a goodmans dual format dvd recorder GDVDR319, tuned in fine, plays fine etc but the picture is pink. Instructions say check the video output but no idea what that means. Thanks
If your normal TV pictures are ok then carefully check your scart plugs are pushed right home and fitting squarely at the TV end and the DVD end.
Jun 14, 2008 | Televison & Video
Goodmans dvd recorder not working
Hey there cyclonesid, capacitors look like little batteries, and have a shiny flat top with perforation lines on it. If the capacitor is going or gone, this flat top begins to peak and sometimes show points of corrosion. jpe is associated with thermal fuses which are used to protect devices from excessive ambient temperatures. These are not expensive and relatively easy to replace (if required) by a professional. I hope this helps. Good Luck!
Feb 04, 2008 | Goodmans DVD2100B DVD Player
Won't do anything
take out the plug and let the set stand for about 30 mins.if that does not work take it to a tech for repairs.the problem is in the power supply or the motor.good luck.
Apr 04, 2007 | iLO DVDR04
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
