Panasonic NV-DS50EN Mini DV Digital Camcorder Logo
Posted on Feb 02, 2010
HI HOW TO USE USB CABLE TO MY PC. NEED TO INSTALL ANY SOFTWARE ?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
2129
Points
13
The usb cable is only for pictures and use is like still cameras, if you need capture video use fire wire cable to connect a computer that need have a fire wire slot. if your pc don't have one buy fire wire card and install on your pc
2answers
Whenever i m connecting the cell phone(nokia 3110 c) with the laptop via USB cable the laptop shows me message that DRIVER missing. i want to use the data cable for net connection. pls let me konow from...
Good Day,
For your driver need, you may just install Nokia PC Suite, where it installs the driver and other necessary software, including the software needed for you to use the phone as an internet device.
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Ovi_Suite_webinstaller_ALL.exe
just go to that link, install the software, and you are set. Please do not connect the USB data cable to the PC yet, until the software installation is finished. After all has been installed just plug the USB data cable in the PC and the phone, and follow the instructions on-screen.
Hope this helps you. Thank you for using Fixya.
Hi there im trying to transfer photos from mu digital camera to my pc, after being instructed to connect the usb cable from camera to computer box comes up telling me that no connection is located?
Please install the software comes with the camera. so that it install the required software along with usb cable drivers then try to connect the camera.
If not work try to check on another USB port. Otherwise check with another usb cable.
2helpful
Can i install software in my nokia 3110 classic cell phone ? if yes then how?
Hi....
To flash(format) you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash(format) *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
For more inf about formatting read my tips and how to do.......
Thank you
1helpful
Hi how can formate 1208 nokia phone
Formating phone is known as Flash
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank you Don't forget rate
1helpful
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
2answers
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
1helpful
HELP!!How to Download pics from i880 to my pc?
Just get you software from http://idenphones.motorola.com/iden/support/software/html/firmware_utility.html#. Install to you PC, connect your phone through USB then your done!
Regards,
Jeep Brainy
2answers
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
have a good long hard pleasurable ...................................................................................................................................................................... think
Have installed the printer( epsom stylus photo 830u on windows xp) and related software when you send a print it just sits in the job que and won't print.The printer is plugged into a usb port which does...
Hi Cheryl,
It's a common mistake to connect the USB cable to your pc
before installing the software. If thats the case, it's probably
the reason why it will not print.
In the past, I have had to disconnect the usb cable, un-install the
the software (sometimes the un-install software is on the CD)
then re-install the software/driver, then when the install software
prompts, plug in the usb.. Or if it does not prompt you to connect
the usb, do so at the end of the software/driver installation. That
is, after you have booted the pc.
Rgds,
dave
14helpful
4answers
W700i drivers
hi,
this is sameer,
i want sony Ericsson w700i usb data cable driver
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
