Question about Lexmark C530dn Laser Printer
I am getting red streaks down my paper when it comes out of the printer. Even if I am not printing in colour. It was working fine yesterday and when I turned it on this morning and started to print, I am getting residual red/pink lines down my page.
    Problem Solver:
  • 14 Answers
Try this! take the cartridge out, Get a piece of kitchen towel, dampen it slightly, not too much!! and dab the cartridge, make sure all excess ink is off. If this dosen't work Clean your rollers, theres a speacial paper you can run through to clean them, try ebay!! hope this helps!
Posted on Feb 02, 2010
Displays colour streaks (mainly red)when printing
you need to make adjustments in the driver control panel color options, you may need service to calibrate the temperature, this can also be a result of poor quality PVC cards. Some card design software will allow you print parts of the card with black panel only which would eliminate this issue.
Mar 08, 2010 | Datacard Group SP35 Card Printer
My printer will not print. The red light comes
My printer will not print. The red light comes on, but there is no paper stuck anywhere. The toner light comes on, but when it did print yesterday, it looked fine. Please let me know what I need to check. Thank you,
Feb 15, 2010 | Brother HL 5140 Laser Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
No black ink printing
Try reinstalling the printer, as it sounds like a driver problem. This shouldn't happen, but occasionally the drivers get corrupted. And refilled cartridges certainly don't help, and may continue to give trouble even when replaced with OEM ones. Have you tried turning the printer completely off - disconnecting the power lead, for a few minutes? That sometimes clears things.
Jun 27, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Fine Coloured streaks on printed page
The most common problem is the photo conductor unit. What ever color the line is change that unit. The Photoconductors are a customer repalcment item.
Jun 04, 2009 | Ricoh Aficio SP-C210SF Printer
Streaks in my pictures
You can clean the print head by using the following procedure from the troubleshooting section of the manual:
Take paper out of the printer
Take a single sheet and put it back in - upside down (i.e. shiny side down).
Close the door and wait for the sheet to eject.
Put all the paper back into the printer in the correct orientation (shiny side up), close the lid and print again.
I've discovered even better results by keeping the special blue sheet that comes with each paper pack. I run the special sheet through before I'm about to use the printer for the first time (after not using it for a few days), and also after every three prints. The result is much better printouts for me. The special blue sheet cleans and calibrates the print head. Just put the blue sheet in the paper tray at the bottom of the stack with the bar code facing down and close the lid. It will automatically eject.
May 11, 2009 | Polaroid PoGo Digital Photo Printer
Printing in all red (lexmark Z715)
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Good Luck
Feb 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
DELL 3000cn Printing Problems
switch off the printer then switch on again whilst holding the UP and DOWN menu scroll buttons simultaneously.
Then you can go to a TEST PRINT area and print off pages of idividual colour.
If the streaks appear on ALL prints its likely to be the laser unit. If the streaks only print on the COLOUR sheets ( not BLACK) then the problem lies with the drum or the transfer belt.
Remove the drum and turn it manually with the gog at the side and give it a clean with a soft LINT FREE cloth, do the same for the transfer belt and then you may have to run a few test prints to get it all reprimed but you should be OK.
Oct 18, 2007 | Dell 3000cn Color Laser Printer
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Lexmark C530dn Laser Printer Logo
191 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
