Question about HP Officejet 5610 All-In-One InkJet Printer
All cables are pluged in and printer will not turn on
  • Damon Hamilton May 11, 2010
    you should try changing the fuse in the plug!
    Problem Solver:
  • 5 Answers
Try changing the fuse in the plug!
Posted on Feb 02, 2010
I am trying to reinstall my mfc brother 260c printer but as soon as i get up to pluging the printer and usb cable in it my computer doesn't seem to know i have so thats as far as i get
Try installing the Brother printer driver first before connecting the printer to the computer.
You can download the Brother printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Dec 15, 2012 | Brother MFC-260C All-In-One InkJet Printer
Had unpluged when pluged back in has no power at all
Check both ends of the power cord (the end connected to the printer might not be in all the way).
Also check to see if the same outlet works for other electronics.
If not, then you have a problem with the outlet not the printer.
Hope this helps!
Mar 06, 2011 | HP Deskjet F335 All-In-One InkJet Printer
My PC says the printer is offline, but it is turned on
if yo have lpt cable check that conjuctions are already pluged well if yo have net work cable check that is'tcut or isolated if your printer have usb cable follow this instruction if all this worked well check your operating system compitible with machine or not especialy if yo used to use linux or macintosh etc or some thing like that
Jan 31, 2011 | Ricoh Office Equipment & Supplies
Unable to turn on printer. It's plugged in to an active power strip. Had been using it earlier with no problem. Any suggestions?
Check the printer power cable for consistance, make sure that the cable is firmly pluged into the print power inlet, if you have another alternative power cable use it to verify, If both Cables give the same results, try a different powe plug in, then if you have the same results, there is a possiblity that your printer power supply is blown. and you may need to replace it, if you can or take it to a near by tech-repair shop for the powersupply replacement.
Dec 03, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer won't POST
Unplug the power cord from the back of the printer and while its unpluged, press and hold # 6 on the printer together for 30 secs and after 30 secs plug the power cable back into the printer while holding it and then after pluging it release the buttons after 6 secs
Nov 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
New usb cable dosent work :S
try to reinstall the drivers and connect the printer afterwards
Oct 20, 2009 | HP LaserJet 1018 Printer
Lexmark X6150 all-in-one printer won't power up
Sounds like the printer has to be taken in for service.
The PSU might by shot.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | Lexmark X6150 All-In-One InkJet Printer
New printer pluged into wall before installing disk nothing work
When this happen, and the USB cable is plugged before installing driver software, Windows will install default drivers, and the printer will not work. I guess that by now the original problem had been solved. I will post a solution to help all users with same problem.
When this happens, just unplug USB, do a System Restore from Programs>Accessories>System Tools. Restart the computer , and reinstall printer drivers.
Regards
Apr 06, 2009 | Lexmark X3650 Printer
I just got this and am trying to istall the driver cd and when i get to the part where it tells me to connect the printer cable to the USB port, i do and it keeps saying it is not found. I tested the...
This might sound funny but make sure the printer is turned on when pluging it in.
You can also try a different port also! If you are using USB Cables
Let me know if that doesn't do it
RJ
Nov 03, 2008 | Office Equipment & Supplies
Mfc 420 does not turn on
Do unplug from power outlet.
Replug again.
Machine should automaticly turn on.
If not, the main circuit board is defective (quite often on machines older than 2.5 years).
If you re an european citizen contact brother for warranty. EU warranty is three years ;-)
If not, you need a new mfc cause spare part cost more then a new one :(
Mar 14, 2008 | Brother MFC 420CN All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
