Question about Dishwashers
I have an AEG OKO FAVORIT 6040 dishwasher. It
I have an AEG OKO FAVORIT 6040 dishwasher. It recently stopped part way through a cycle. None of the controls appear to work but there is the constant sound of a pump which only stops when the machine is disconnected from the plug. I guess this is the anti flood device. Is this likely to be a fault or can it be easily rectified?
  • Christopher Poole Jan 09, 2013
    I had the same problem and followed Joe Lishman\'s directions below it took just under an hour to isolate the water stop cock get the machine out and dry the base, Im pleased to say that the machine is working fine ! THANKS VERY MUCH
SOURCE: Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Posted on Jan 19, 2009
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
SOURCE: aeg favorit 64070vi, i 30 fault, think that the
Thanks to all.
What we couldn't work out is what is actual mechanism of anti-flood triggering, and how therefore to reset it - and why all these other fixes work - but then it occurred to us, that problem is when water gets into the base and can't get out.
Our problem was that water inlet at top of washer came loose so water ran down outside the drum but inside the dishwasher, into the base. We tried the tipping method but this just moved water around and I think there must be sensor there which, if it stays wet, leaves anti-flood triggered.
This makes sense because other high level overflows from drum discharge into base - so if it was to overflow, it goes into sealed base only, wets the sensor and triggers anti-flood.
Our solution was patience - tipped it fully on its side, pointed a hot air blower into it for hour or so, then left it overnight. Tipped it back next morning, water which had run into side panel ran out, so it was upright with its base dry - and (touch wood) it worked like a charm.
Posted on Jun 08, 2010
SOURCE: AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Posted on Sep 11, 2010
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
AEG Favorit 6040 Dishwasher has continuous tone (from Pump?) even when switched off at the power button. It cannot be set to any programme.It overflowed some froth when put on a recent cleaning 'phantom...
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Nov 11, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
How to Start And use ???
I have the 6040 model, and it has a number of buttons on the left, and a dial on the right.
if yours is the same, then you need to select a program using the buttons "Normal" for example, then turn the dial to just after the top A selection (I mean just after this, by a few mm, it clicks past the A slightly)
this will then do a pre-was, and the main wash you have selected.
The other buttons are fairly self explanatory, like half load for a half load, pre wash to only do a pre wash etc...
Hope the helps!
May 23, 2009 | Ariston Technologies Dishwashers
Jan 17, 2009 | Dishwashers
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
179 people viewed this question
Top Dishwashers Experts
