Question about HP DeskJet F380 All-In-One Printer
Power problem when I switch it on,it autmatic switch off. It is just blink on and of.
    Problem Solver:
  • 18 Answers
1. push the adaptor's jack firmly
2. change the adaptor jack(after checking the power voltage with multimeter the out put voltage should be 32v and 16v)
3.replace the cartrige
Posted on Feb 20, 2008
What is causing the black screen and 3 blink light?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 16, 2014 | Panasonic VIERA TC-P60GT50 60-Inch 1080p...
No electric power unless you wiggle gear autmatic gear shift.
there's possibly a problem on the connection on the wiring into the switch.. try to check the wiring connections...
thank you
Jul 29, 2008 | Plymouth Grand Voyager Cars & Trucks
Power steering leaking
Hi Kirk, I'm glad to help!
Kirk, power steering leaks can come from any part of the power steering system. Fluid can leak from seals on the hoses, the hoses themselves, the power steering pump, the power steering gear assembly, usually leaks from the seals at the end of the gear behind the long boots. These are a few things you can check and see what part you need to replace. Hope this helps and have an awesome day Kirk.
Mar 04, 2013 | 2006 Mazda 6 2.3
Whenever i switched on my n73 it goes to camera mode autmatically, give me the solution
make sure the camera button is not stuck ..... if not then you should install the api file explorer and go to "c" instance and you can find the camera in the startup folder. but its for advanced user and so better do a reset settings it will fix
Aug 31, 2010 | Nokia N73 Cellular Phone
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Losing Power/ignition 2005 Jetta GLI
Check out the vwfixx.com forum online. One guy has a step by step procedure on removing the ignition, says it takes about a half an hour.
Apr 02, 2009 | 1998 Volkswagen Jetta
Bxi combe 80e - should the screw on the autmatic
according to observation of similar boiler, the screw on the relief valve is shut.
Feb 27, 2009 | Combi Centre DX - Mango
1972 moblile home heater does not work automatically
alot of times those switches go bad and poeple just by-pass them those switches operate in this fashion...when you put the fan to automatic it will only come on when the heat or cool is turned on when you put the switch to on the fan will run continueously ie the switch usually will be labled Auto- Off - On
Jan 06, 2009 | Heating & Cooling
Camera lens
This is a simple one. The lens is tilted at an angle. Most likely you will find your lens cap doesn't fit correctly and all you need to do is align the lens correctly. Then when you turn on the power, the lens will autmatically extend.
Jan 11, 2008 | Kodak EasyShare Z7590 Digital Camera
HP DeskJet F380 All-In-One Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
