Question about Bosch 24 in. SHU43 Built-in Dishwasher
A tap has appeared. Why?
On the LED screen, there is a tap, and the machine is not working.
  • Bosch Master
  • 12,061 Answers
Loss of water/ water pressure .. at least a sensor is telling it that. Time for the serviceman. Get A "Quote" first.
Posted on Feb 02, 2010
Why when turning on blaupunkt 1080p led hd tv i only get a black screen there is start up menu
If you tap "gently" on the front screen do you see whiteish color?
If no you have a problem with the set. probable power supply issue.
If you do then press menu. If you don't see the menu on screen, probable control board issue or lvds board. Time for a tech.
Jul 29, 2014 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
No display when turned on?
Try to turn it off, remove all power source (battery,adapter). Press and hold power button for 10-15 seconds. Power it on, tap on F2 right after you power it on, if a BIOS screen appears tap on F9 select Yes, then tap on F10 to Save and restart. If these wont work try to connect an external monitor.
Sep 20, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
F1 PROBLEM ON VACMASTER VP540?
I found this information related to a different model of the Vacmaster:
If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
Mar 25, 2013 | Vacmaster Vacuum Pack Machines: VP540C...
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
My whirlpool duet washing machine is making s strange hum and appears that the water is entering slower. I've checked the water taps and don't see anything different than before. Any suggestions?
In addation to checking the actual taps,also check where the hoses connect to at the rear of the washer for sediment build up in the filter screens...also while hoses are disconnected from the washer while checking the screens also place hoses in bucket and turn on taps and see if good water flow is coming from the hoses/taps. If screens are clear and water flow through hoses is good the water inlet valve the hoses attach to would need to be replaced.
GENE
Sep 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
Screen remains blank although at times the machine gives directions.
Tap on: the main screen. Tap on: Change Preference. Tap on: Arrow Keep tapping on the arrow till you reach Preferences 6 of 6 Page. Here you will find Battery saving preference. Tap on it. Tap on: Never dim screen. (I think your selection would be dim screen between instructions at present.). Tap done. On the next screen select : Device stays on when external power is lost. (A green tick mark should appear to verify it is selected.) Tap done.
May 10, 2010 | Tomtom GO 930 GPS Receiver
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Bosch 24 in. SHU43 Built-in Dishwasher Logo
354 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
