Question about Fisher and Paykel DD605FD Stainless Steel Built-in Dishwasher
Fisher & Paykel DD60DCX6 Top drawer timer stops mid way through clean but dishwasher keeps going - does not prgress to rinse cycle and makes random unsual noises
  • 1,284 Answers
Hi, from the explanation made above, i sounds like the motor is faulty and needs to be replaced.......
Take care
Posted on Feb 02, 2010
I have a fisher pakel double drawer dishwasher and it keeps pausing a couple of times through the cycle how do I stop this
Pausing - how long? The pause means the wash motor keeps halting as it is waiting for the water temperature to increase to the right wash selection. If the heater is sluggish then it will take longer to heat. Try a simple rinse cycle and see if there is any difference. (Rinse cycle will use cold water to complete)
Dec 04, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a Fisher and Paykel 2-drawer dishwasher. The top drawer is stuck in the rinse cycle and I cannot change it to another cycle. Please advise.
Assuming the controller of the top drawer is still ok, take a clean damp cloth and wipe the top panel where the program keys are located.
If nothing happens, you will have to check if the controller connector is not loose. Take the front cover off and check the controller connectors.
Please rate this solution to help fixya serve you better in future.
Sep 16, 2010 | Fisher and Paykel 23 in. DD603H SS...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD605FD Stainless Steel Built-in Dishwasher Logo
534 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
