Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchenaid Model ksrs22q or ksrb22q
Our refrigerator came with the house when we bought it in June 2009. It was originally purchased in 1993.There are black specks on the ice, even though we've dumped it all several times. Also, there is no filter light-is there a filter? we have the Use and Care Guide-doesn't mention a filter. The water tastes "off". Is there a way to get rid of the black specks? Is it time to get a new refrigerator?
  • KitchenAid Master
  • 3,740 Answers
Hi, It sounds like maybe the house sat vacant for a long period of time.
The black specks can be from several sources but these are the 3 most common:
1. The internal and back of the fridge plastic tubing used to route the water from the water valve to the icemaker
a. If water sat in the tubing for months and there was decay of the water quality then the black gunk can build up in the plastic lines. You can clean the ice maker supply line on the back of the unit with bleached water after you gently pull the upper part of the hose from the fitting and unhook the lower part of the plastic hose from the water valve. Wear rubber gloves and be prepaired for bleached water drips. Just make sure you purge the line with fresh water after bleaching and then reconnect it on BOTH ends. I know it is not easy to get water into that tiny little hole.
Usually the water is turned off and the water line is disconnected on a refrigerator that is to sit idle of a long time and the water will drain back and out of the interan water lines of the unit.
2. It can be from plumbing that sat unused for a long period of time.
a. You can buy an in-line water filter usually for under $25.00 and install it on the 1/4 input line to your fridge (The filter kits come with installation instructions) An easy job for anyone that can follow an instruction sheet.
b. If you do install an in-line water filter purge the water line in a bucket by turning on the supply valve and fill the bucket about half full of water then turn off the water in install the filter.
3. The diaphram in the water vavle dried up when the unit was idle. The diaphram rubber could have broke down from being dry and is now showing up in your ice as black specs.
I would not give up on the unit yet.... It sounds like with a little persistence it will be fine.
Posted on Feb 02, 2010
Testimonial: "Thanks so much for the options and helpful advice"
I've ordered 2307028 board for ref. Condenser fan motor quit running and a technician said it was this board. He said that this board is not the one inside ref. He said it was located in back of ref....
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSBP25INSS03/0593/0165000/W0706015/00011 it is #19.
It is located under the refrigerator behind a plastic housing, follwing the wiring harness and you should be able to find it. Make sure the unit is unplugged and that you let it sit for some time to discharge residual power. And try not to handle the replacement board more than you have to and NOT on carpet - static electricity.
Jul 01, 2011 | KitchenAid KSBP25IN Side by Side...
Does Kitcheaid Model KSRS22Q contain SO2?
Hello, Welcome to FixYa. To answer your question in a word, No there is no sulfer dioxide in any modern refrigerators that I know of. They pretty much all use a refrigerant called R134a which has been the standard for 15yrs. or so...depending in what country you reside of course, this applies to North America. You may want to contact Whirlpool (manufacturer of Kitchen Aid appliances) for more info if outside of North America. Hope that answers your question. Thank you for choosing FixYa today. Please take moment to rate the info provided. Regards, Macmarkus :)
Apr 01, 2011 | KitchenAid (KSRD22FKST) Side by Side...
My manual has been wrongly put together viz, pages run from 1-6, 11-14, 11-18, 15-18, 23-36. Unfortunately i have been ill since I bought the overlocker in June 2009 so it has just come to my notice,
Contact your dealer. Even if you purchased 1.5 years ago, you can still take the manual in and they can get you a replacement for it. Worst case, they will be able to get you a copy of the original.
Let me know who your dealer is and I will be happy to contact them and give them the necessary information to get a copy.
Dec 13, 2010 | Husqvarna Sewing Machines
Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Jan 29, 2010 | Refrigerators
I just replaced the start relay (start device) on our KitchenAid side by side refrigerator. The new relay I received was exactly like the original except it did not come with the plug in capacitor. I...
Leave the capacitor on and don't worry about the cover. The capacitor really helps the compressor to not use as much electricity, thus saving energy.
Jan 06, 2010 | KitchenAid Refrigerators
Water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Mar 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Mar 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
735 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
