Question about IBM ThinkPad T23 2647 Notebook
Fan turns on and off rapidly
I recently replaced the mainboard because when I turn on the power the light would come on but no response from anything. Now the screen lights up, the drives start up and the fan turns on and off repeatedly. I went through and checked all connections again. I am out of ideas. Can you please help!!!
    Scholar:
  • 101 Answers
The fan cycling problem on the T23 series usually indicates a loose solder or missing inductor which is usually on the underside beneath the PCMCIA slot. If you replaced the mobo yourself you may have flexed what is a weak solder joint loose - you will need to pull the board and resolder this or have someone else do this for you. You can sometimes get the laptop to start by flexing the assembled laptop gently around the PCMCIA slot and if so then that almost always means an inductor problem. You can find some photos by googling (images) "T23 mobo" or "T23 motherboard".
Posted on Feb 20, 2008
Ceiling fan and light
First replace batteries in remote, go to breaker switch and see if power is going to fan,turn off and turn back on,then try,if it still doesn't work,turn power off at breaker,then remove fan to get to wires and check to see if power isgoing to fan,if it is then fan switch is bad.
Dec 23, 2012 | Dryers
Olevia 237V: Blue panel light glows but TV does not turn on
I am working on the same issue. It is either the power supply or invertor board. Please let me know if you find anything out. did you open the tv and check the power supply for bulging caps?
Feb 12, 2010 | Olevia 237T 37 in. LCD TV
My toshiba laptop no response
If its not doing anything at all ,your power board may be bad as well as your ac adapter maybe faulty.Also the power jack where the adapter plugs in may need resoldering or replaced.
Jul 28, 2009 | Toshiba Satellite L305-S5907 Laptop
Dll and exe corrupt errors, causing shutting down after booting
Easy solution is there :
Check the fan with external power (12v. DC). If damaged replace it. Give a clean windows installation when the fan is OK.
If your mainboard does not supply power to the fan than you have a major problem with mainboard. Replace mainboard.
Feb 23, 2009 | Dell Inspiron 1501 Notebook
Fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Fuji F460 no power
Mainboard component failure at a guess or the new battery is not up to scratch- try taking the battery back for a new one as it is a recent purchase. If you can do that and still in trouble contact Fiji for a reapair estimate.
Aug 29, 2007 | Fuji FinePix F460 Digital Camera
IBM ThinkPad T23 2647 Notebook Logo
106 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
