Question about Eiki LC-XNB5M projector lamp Projector Lamp
Eiki LC-XNB5M projector suddenly shuts down
I got Eiki LC-XNB5M projector, wich suddenly stopped working.
When powering on, fans go on, and after few seconds i can hear fan sounds lowering a slightly, light doesnt seem to work, and after while it autoshuts down, propably cos no image etc.
Any advices what could be the problem?
Filters cleaned, lamp connections checked, tried to reset, nothing seems to work..
Used to have it connected to pc. One day it worked, after woked up next day, it suddenly wouldnt work.
New lamp is 200e, but not wise buy if not sure its the lamp.
And lamp replacement counter light hasnt turned on.
Advices?
5 Suggested Answers
  • 45 Answers
SOURCE: I have a eiki lc-xnb5m projector that seems to be
there is a heat sensor, i had a same problem, and it turned out to be this dumb thing, if projector get's to heated up it shut's down to save the electrical components from burnig out
Posted on Oct 29, 2009
projdoc
  • 2236 Answers
SOURCE: Eiki LC-XG110 lamp going off
the lamp may be at the end of it's life.
Posted on Nov 18, 2009
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
heathgr
  • 442 Answers
SOURCE: My church has an EIKI
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Posted on Mar 24, 2011
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Mar 24, 2011 | Eiki LC-X986 Projector
Fan will not turn off after lamp cools down. fan will run for days.
is this after auto shut down ? check menu setting if this is set to READY, then it will wait until signal appears again at the input. You can set this better to "shut down", PJ will go to standby after cooling period and fans will stop.
Nov 10, 2010 | Eiki LC-X50M Projector
I have a eiki lc-xnb5m projector that seems to be shutting down if it's ceiling mounted, but runs fine on a cart. I know it sounds strange, but, is there some sort of gravity sensor or levelling sensor or...
Oct 29, 2009 | Eiki LC-XNB5M projector lamp Projector...
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
My eiki LC-xnb4m will power on but shuts off after about 60 seconds. It doesn't shut off completely.it just drops the input signal (audio and video) and the fan kicks on heavy for a few minutes. Then...
may be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Jul 01, 2009 | Eiki LC-XE10 Projector Multimedia...
I have an Eiki LC XBN4 that starts and then shuts down within a few seconds
check the lamp for black spots and bulges. if you have any, replace it. if not, you have a ballast/power supply issue.
Jun 24, 2009 | Eiki LC XNB4 LCD Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
104 people viewed this question
Top Eiki Office Equipment & Supplies Experts
Jaime Hernandez
color wheel light...
Jerry Kramer
Jerry Kramer
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
