Question about Refrigerators
Need kit to convert my whirlpool fridge from rhs to lhs hinge
I am looking for a kit which will enable me to convert my whirlpool fridge from being hinged on the Right Hand Side to being hinged on the LHS which will suit my new kitchen layout. this is the information I have found on the fridge so far.
please let me know if this will be enough to identify my fridge
yours faithfully Ms Sarah Sykes
email sarahsykes@internode.on.net
  • 417 Answers
you may not have to buy anything, on most reversible door installations you just use the same hardware, just turn the hardware upside down or the other way around, same with the handles. look at the hinges closely, on the other side of the door is plastic caps, you just remove them and reinstall the door starting from the very bottom hinge. If there is a kit Im sorry, but Ive never had to buy any sort of kit and Ive done at least 10 fridges..
jm
Posted on Feb 02, 2010
Euro grand bar fridge glass front. Have just replaced curcuit as supplied as apparently all had 100 % failure rate! We bought 3 including dual zone wine fridge. Have replaced boatds, but not not cooling...
If these were bought new, it sounds to me like the company still has a problem with their control boards. I would get the manufacturer on the phone and ask to talk to someone in Engineering.
If bought used, be sure they are set up for the proper supply voltage.
Nov 17, 2013 | Furniture
Tip
C45 Cross Trainer drive belt replacement
Needs
Cost = £25 for drive belt + any tools needed (saving of £150 - £200).
Tools = Long shafted crosshead screwdriver, 3 & 4 & 6mm hex keys, metric spanners, ratchet tie-down luggage straps (2), wire twists.
Time = 3-4 hours.
Difficulty = Moderate.
General
The 15mm grooved belt is tensioned by a spring loaded jockey pulley. Dealing with this is the crux. Handing is relative to front view of the machine. Beware of magnetic field near brake when running under load - pace-makers, watches etc.
Procedure
1. Disconnect dc supply and remove plug. Clear access is needed to both sides, with most of the work done from RHS.
2. Disconnect both drive arms from the drive discs using hex key. Pull front ends outwards to clear the trunnions. Push both arms back out of the way. (Drive discs cannot be removed without special tools).
3. Remove RHS cover using crosshead driver to undo screws in deep slots round edge.
4. Remove dc socket from LHS cover (hex nut) before removing LHS cover.
5. Working from RHS, note layout of electromagnet brake unit. Cut out old belt. Remove jockey spring.
6. Plates on either side clamp the magnet core. Remove the RHS plate only (which also carries the jockey pulley crank). Remove hex nut on end of brake pulley shaft. Use spanner and hex key to remove 4 long bolts one at a time and partially reinsert each from LHS - this prevents the short aluminium spacers on LHS from falling out. Don't lose the long spacers or the crank mounting bell washer from RHS. Remove 2 short screws from lower edge of plate using hex key. Each has a plain and a spring washer. Do not slacken the corresponding 2 screws on LHS, since that risks disturbing the distance between the driving and brake axes.
7. Remove old belt debris and clean.
8. Pass new belt over RHS drive disc. Fit centrally into grooves on topside of disc only, leaving enough slack to fit centrally round the small brake pulley.
9. Grease mounting washer and replace crank with jockey pulley hanging underneath belt. Refit RHS plate, starting with the spindle hex nut. Take care that each bolt passes through both long and short aluminium spacers. (There seems no reason to remove and reinsert the bolts from RHS - this only increases the chance of dislodging the small spacers). If a spacer does move, use a wire twist to hold in place temporarily while inserting bolt. Ensure that all bolts and screws are fully tightened before step 10.
10. Refit jockey spring, ensuring that the pulley pushes against belt's lower surface. Anchor ratchet tie-down to back foot of machine, wrap round crank arm, then pull back spring as far as possible. Use 2 tie-downs for safety and maximum tension.
11. Slowly rotate RHS drive disc anticlockwise while keeping belt central on both pulleys. Use a screwdriver blade to prevent the belt jumping the grooves on the brake pulley and slipping off the jockey pulley. Once the belt is grooved, keep turning to check that it runs true - no grooves should be visible on the brake pulley. Use side pressure while turning to re-position. Mind your fingers.
12. Release tie-downs very carefully, since the spring reacts with a bang. Temporarily attach drive arms and dc supply. Test. When satisfied that all is OK and belt runs true under load, detach drive arms, replace LHS cover, dc socket, RHS cover, drive arms, and plug in dc supply.
on Jan 22, 2015 | Tunturi Exercise & Fitness
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and break.it is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the unit.buy the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 | Dishwashers
Squeak - Squeak
if it is kitchenaid/whirlpool unit it has 2 nylon ropes that connect door hinges to the springs on either side of door hinges.these ropes slide over plastic wheels and with time it stars making noise.just cln those wheels and apply little bit of regular bearing grease on those plastic wheel.noise wil go away.to do this u have to pull the unit half way out to access those wheels on lhs and rhs lower front end corners of the unit.good luck.
Aug 15, 2009 | Dishwashers
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Change default external monitor to LHS not RHS
yes you must change the properties settings to its original resolution values maybe 1024x768 pixels
Apr 01, 2009 | Microsoft Windows XP Professional
2001 Audi A6 how to bypass the original amp
The stock amp (mounted inside the sub enclosure) found on the RHS of the boot behind the pull out pannel has a red plug with 8 twisted pairs of wires and 3 other wires (pos, acc and earth).
Out of the twisted pairs you will have
RHS Rear Speaker: Blue/Gray +, Gray/Blue -
LHS Rear Speaker: Red/Gray +, Gray/Red -
You will also have a pair of White/Blue and Brown/White which is the RHS input and a White/Red Brown/White pair for the LHS input. Although... the stock amp uses a common earth input as you will see, the two Brown/White wires going into the same plug.
To put in another amp, you will need one with 'high level' input. Make sure it can take a common ground type input. If it cannot then just use a "high level to RCA" converter.
If you are putting in an after market headunit like i did, then you will just need to separate the two brown/white wires at both ends. If you do this you will need to test which brown/white wire at the head unit end is paired with which wire at the amp end. They are twisted together at the amp end but not at the headunit end (unless you cut the cloth tape back far enough).
Dec 11, 2008 | 2001 Audi A6
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
