Question about eMachines eMD620-5133 Notebook
Laptop screen going black inwards from right hand side
  • 115 Answers
Please replace the screen.
Regards
Ashly
Posted on Feb 02, 2010
I have just had a new screen fitted to my toshiba c660-10t but now about 2 inches on the right hand side is black like the screen is ended and half the tool bar at the bottom is missing
Go to control panel, select display, click on settings top right, go to resolutions and highlight your mouse over the arrow move one notch to the right and click apply, another window will pop up asking do you want to save these changes, click ok, repeat process until the desired results are reached.
Jun 16, 2012 | Toshiba Computers & Internet
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
CANNOT FIND WHERE U PUT BLACK AND WHITE WIRE THAT GO AROUND SCREEN ,TOSHIBA L455D
One wire runs up the left hand side and the other runs up the right hand side of ther screen and stick to the pieces od double sided copper in towards the top centre ot the screen. The position is not critical at all. As long as they are somewhere near, it is fine.
Jan 29, 2011 | Toshiba Satellite L455DS5976 Notebook
Monitor keeps glitching. right side of screen completely black. is there a way to reset the monitor
Hi
Thank you for your query
If your monitor is black on the right hand side, this indicates that the LCD screen may be burned out
Please try the following
1) Switch on Laptop
2) Continuously press the F8 key until a start up menu presents itslef
3) Choose safe mode
4) Oncein safe mode look at the screen, i believe it will be the same
If so you will need to book the laptop in as part of the screen has burnt out
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Compaq Presario Notebook
Help!
the reason for the weird lines is because the lcd is going bad and will need to be replaced.
Aug 21, 2009 | Compaq Presario M2000 Notebook
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
My acer screen is partially black
I beleive the chips in the screens outer edge have been damaged so only option is to replace lcd screen or use an external monitor
Jan 30, 2009 | Acer Aspire 3680 Laptop
Screen has a vertical black band on right hand side
You might have a centering control among the options of your monitor. Look up the manual, or just play with the buttons until you find it.
Apr 07, 2017 | Nu Mark Computers & Internet
Black screen on the right side of my acer 5630
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
Nov 25, 2008 | Acer Aspire 5630 Notebook
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
eMachines eMD620-5133 Notebook Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
