Question about Dell V305w All-In-One R840635AU InkJet Printer
I want to print some thick card. Will this damage the printers feed or is there an adjustment setting?
  • Dell Master
  • 12,061 Answers
As long as it is a straight path through the printers platen, & it is not too thick, then often you can feed single sheets through... more suited to stiff card.
Posted on Feb 02, 2010
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
Won't print and the hand with the cloth light is lit. Put in a cleaning card and held down the feed but the card is still in the hopper.
Open printer properties . Click on Tools tab.
Click on printer Self Cleaning button.
Remove any ribbon from printer and cards from feeder.
Adjust thickness lever just near feeder to full 1mm.
Insert cleaning card in feeder and click on start cleaning button.
This should definitely solve your problem.
Feb 17, 2011 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4 printer. I am trying to print out cards from the Pebble 4, but the machine is not pulling the cards from the card holding tray. Because the cards are not being pulled from the...
Just check for thickness adjustment pointer near card feeder . It should be 0.8 for standard cards.
Check in driver settings also if you have selected for manual feeding.
You may need to clean the Roller situated at feeder.
Oct 14, 2010 | Evolis Pebble Color Card Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Resolving a Card not fed error (Cards will not feed off the Hopper)
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Dell V305w All-In-One R840635AU InkJet Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
