GE washer (WCXR1070T5WW) hot water does not come on, and water does not shut off. What is the problem/solution?
  • mtech_orams Feb 03, 2010
    the hot water from the water heater is not getting through to the machine. With the setting on "hot wash", and the cold water turned off, the hot water does come in. When the cold water is turned on, it "overpowers(?)" the incoming hot water. The point of coming to this site is to avoid calling a service man.
  • mtech_orams Feb 05, 2010
    FYI to all. The water valve was sticking. I removed it, removed the coils from it, let it soak in Zep "clr", re assembled and re installed it, and it worked.
  • 12,061 Answers
Sounds like a microprocessor problem thats not heating the water and not shutting off the water solenoid. I reckon it's time for a serviceman, always ask for a "Quote" before ever proceeding
Posted on Feb 02, 2010
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
Ge washer wjre5550h01ww
The water inlet valve is stuck open.the inlet valve is baby blue located in the back of washer. Shut water off to machine first then remove cold and hot water line from back of machine fr
Sep 01, 2012 | GE Washing Machines
I have a GE model WCXR1070T5WW washer that will no longer stop filling. I suspect that the water level pressure switch simple went out as part of the general course of things, but our maintenance man...
while i do not want to get involved in the middle of anything. I my 30 years appliance repair career i have never seen a water level switch short out due to over loading EVER!!
Aug 13, 2011 | Washing Machines
Water keeps running in i have got to cut water off to spin dry
There is an electrically controlled water valve for both hot and cold water on the back of the washer, do both settings not shut off? if it is just the cold pull the washer out and replace the cold water solenoid water valve.
Mar 10, 2011 | GE WSXH208A Front Load Washer
GE Washing Machine That the Water Does Not Cut Off!
your washer valve is sticking, it should probably be replaced
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
GE WCXR1070T5WW washes OK but won't spin and drain
It depends on what type of pump it has.If its an electric pump it could drain without spinning,but if the pump runs off the same motor as the washer then the motor has to be running for it to drain,and it will probably spin.There is no guarantee,but the switch that closes when you shut your washers lid is probably bad.Try bypassing this switch,and see if it spins.Please if it spins replace this switch.It is a safety measure that you should really want to keep intact.
Jun 05, 2009 | Washing Machines
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me gary1121@aol.com let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
GE washing machine overflows water fill will not shut off
You just have to replace the inlet valve, can do it yourself.
Jun 13, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
