Question about Dell E173FPb 17" TFT LCD Monitor
LIGHT VIEW 17" TFT MONITOR LM17SB OUT OF RANGE WHEN USING WINDOWS 7 WORKS FINE WITH VISTA
  • 115 Answers
Set your resolution from "Display" which you can find in control panel. And fix the resolution at 1280 by 768.
Regards
Ashly
Posted on Feb 02, 2010
Testimonial: "Changed setting but still same result. Installed latest driver for NVIDIA onboard graphics card and still same. Fitted pci graphics and now ok. Thanks"
I cant find driver for my flat panel monitor Dell E172fp for windows 7 64 bit... It is a big problem... Can someone help me? Sorry about my english.
It is a "plug-and-play" monitor, which is fully-supported by Windows XP/Vista/7, in both 32-bit and 64-bit modes.
What manufacturer of computer?
What model of computer?
Desktop or laptop?
Use "Control Panel" and then "Hardware" to view the details about the video-card.
Aug 18, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
I've upgraded operating system to Vista and can't find drivers for Dell 1703FPs
Have you tried to download from Dell support site. Support.dell.com
Eventhough it doesn't list Vista as an option it should work. XP 1703FPs
driver should work on Vista.
Jan 23, 2011 | Dell 1703FPs 17" TFT LCD Flat Panel...
Installed windows 7 on a dell sx260 with gem 17 lcd cant get display drivers to work?screen all dis colored
Try going to the Dell or Microsoft Websites and loading a new display driver for Windows 7. When I first got Windows 7, both my monitor and printers required new drivers for Windows 7. It seems that Vista and XP drivers for a lot of things don't work on Win 7.
Good Luck
Dec 08, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
I can't get the screen up. I see its plugged in
Does it work with Desk top PC OK?
When you use it with laptop, you need to use Fn key and either F4,5,6, or 7 depends on your laptop to select how the display will work: both, extenal ony, internal. Please post back.
http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | BenQ T701 TFT 17" LCD Monitor
My monitor LM17sb develops red dots in the grey areas which come and goes. Can I fix this
It sounds to me like there could be a short-circuit developing in the panel, or the wire that connects the monitor cable to the inner panel, since it comes and goes. I hope that monitor is under warranty. If not, you can either accept that the monitor will occasionally short, or you can replace it. Fortunately, you can get 17 inch lcd monitors for about 80 bucks, rather than 150 just a few years ago. Currently, there is no way to fix a broken or shorting monitor without replacing it or having it repaired.
Nov 05, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Too much magenta
Click Here to view the answer to this question.
Nov 18, 2008 | Philips 170B4MG 17" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
219 people viewed this question
Alun Cox
